Dustyflannel
- Joined
- Jan 6, 2022
- Messages
- 68
Made a purchase. First, I want to thank everyone that commented! I read them all, and considered them carefully. In the end, I took your input and evaluated the actual machine in person. So, I went with the Rockwell 15-655. My shop floor is wood framing(Rockwell is 100 lbs. lighter), and I drill more wood than metal. I was able to test it and it ran well. The VS is pretty sweet(although more complex, and prob expensive to fix) and seemed to be in working order(more on this in a moment). No cracks in casting/pulleys (I looked over the pulley/sheaves? as well as I could), table up/down nice. Not sure if this has belt tension- I need to learn. It ran quietly and without vibration(under normal conditions) and made nice holes in wood. We had no metal to test(my bad). Now, for specifics: The seller did not have true 3ph (which he told me before I went to see the DP, 4hr. round trip). He had a VFD and he said that when he started the drill on high rpm it would pop his VFD. So, we were only able to run from low to a little over half speed, but it seemed to run beautifully at those speeds. Easy to shift, no vibrations. But, the speed dial would not go all the way to the lowest setting(seller had no answer for this), so, I don't know if whoever put the new "clutch plates" (or are they called sheaves?) on the machine just didn't adjust it all correctly or something else. Also, the hand dial for rpm seemed to drift a little, not cool. He assured me that there was a tension bolt/set screw/adjustment on the dial that would fix this(right now I can't remember if this drifted up or down) it seems the spring tension on the top sheave(motor side not spindle side) could also affect this(not sure if that's adjustable). Also, even though it seemed to drill well, and without any noises/vibrations, I extended the spindle half way, then all the way while running and applied pressure to the front of the quill(pushing it towards the support column). When I did this, there was a new noise/grind/rattle(minor, couldn't feel it but, I could hear it) from somewhere in the housing/upper spindle area. Probably bearings. Neither the quill nor spindle seemed to have any play/slop. I have taken many photo's so that I can post specific questions w/images in the future. But, the first order of business is to purchase the correct VFD and get it up and running. The DP came with a panel attached with lots of wires inside(see pic). I will need help with this for anyone willing, ty. I would greatly appreciate any and all comments on any of these issues. Thank you all, Dustin
