Has snap on tools changed (for better or worse?)
DAustin
In Sept. of 21, I ask the Snap-on driver to order me a 7pc. 6pt metric combination wrench set. I've called him once a month since then and it's always "on backorder". The driver is a young guy and seems really nice, but I think he's blowing smoke up my *** about this order. For me it's gotten to be a game to see how long it will take to get them. Thankfully I don't need them that much right now or I would have ordered them online. I was just trying to support this truck guy. I'll give him a call tomorrow when he's in the neighborhood and if he doesn't have them, I'll cancel my order and go online.
CGarage
United States/Switzerland
Tons of tools are on back order. Call Snap-On corporate and ask to see what the ETA is.
1 (877) 762-7664
I tried to get motor oil yesterday to do an oil change on a vehicle. Even the specialty European motor oil was not in stock and backordered due to COVID.
DAustin
I have to know… What spurred one of the most epic thread resurrections I’ve ever seen on the internet?
I had no idea this thread was that old. I'm thinking it was something that popped up on similar threads on the bottom of the page of another thread. I admit I don't always look at the date of the first post when answering a thread.
Alpine4x4
Central, WA
Thats pretty common right now. Snappys website has a long list of items on backorder. My roll cart has been on order for three months now.
Wrench97
Southeastern Pa
1 (877) 762-7664
I have a 120lb keg of grease on back order along with Mobilith SHC 007 wheel bearing grease for 2 months now.
JHB
I just ordered several new sets of wrenches from snap on, and I'm not impressed with the chrome.
These are new, part of a master set in foam, never been used. Thoughts?
Ton ton
Page County,VA
Even Napa seems to be getting slower when ordering tools through them. I'm just happy when the stuff finally shows up.
drtyler
Go turn some bolts with them. They'll be fine.
Ton ton
Page County,VA
If you want to dispose of these wrenches, I would not mind paying the shipping on them to get them to my house. They look fine to me.
JHB
I realize that they will work just fine, this is more a question of principle.
Is this a normal condition?
drtyler
I have received similar from Snap-on (XDHM wrenches). Only a few like that, but it didn’t reallu bother me.
Steve_P
Yes. They are placed on a rack for plating- the rack goes into the tank. The item has to hang on something which blocks the plating in the area where the hook, etc, contacts the wrench. My Williams wrenches are the same
JHB
Thank you for the replies.
The entire wrench is submerged in the bath. Anything else would be impractical, as it required to conduct current and would be impossible to control wicking. I realize the wrenches are suspended from one end during the process. None the less, I had a look at some of my Asian sets and they are all more finished inside the open and box ends. Furthermore, some of the snap on wrenches are flawless on both ends, indicating that the finish I am looking for is obtainable, but inconsistent.
I ended up cleaning and polishing the inside ends of all of my wrenches, so that they do not always look dirty. Attached is a before and after of the 18mm box end. I found the insides of many wrenches are essentially unpolished. Although bothersome for **** folks like myself, the chrome plating appears to have continuity and should not be susceptible to corrosion in the future.
Call me crazy, but when you pay this much for hand tools, they should be polished inside and out.
JHB
Correct, I wrapped various abrasive pads around the handle to remove the scale on the inside of the smaller box ends. I also use it for detailing the interior of my vehicles (air vent slats, around radio buttons, etc.).
Ricky Joe
Roanoke, Va.
I actually prefer the inside to not be plated, as plating eventually flakes off and that changes the size and fit. I won’t buy wrenches plated on the working surface.
f121
UK
Yes there many very good tool makers in the world but around here only one of them shows up within a couple hours to fix a broken tool you need to do a job or to sell you a tool you need to do a job sitting on a lift half apart. He's not the cheapest guy in town but what he is selling is service and a good product.
It totally depends on the driver, ours is clearly making too much money and has stopped showing up, think I have seen him once since October. Meanwhile amazon delivers tools next day and the local big box stores are open till 8pm, and if I get really stuck for the vehicle in pieces, someone will lend me a tool.
M635_Guy
NC
I agree the wrenches are 100% fine. His point is that for the absolute premium charged by Snap On, the expectation of the finishing should be high. If this were an Icon set people would be squawking about how Icon cuts corners/etc.
I swapped out my Xframes because the chrome was flawed on almost all of them and I didn't want to deal with a warranty scenario later with that many things in a set, and frankly I expected better. The replacement set is great. I'd 100% hold SnapOn to a high standard. At that price, finish your damn tools or charge me a blem price.
JHB
Here is a 1/2'' drive socket that I received last month. It is worth saying that snap on has been great, and returned the defective socket(s) (there were three) without hesitation. Here are my thoughts:
1. This is a clear visual defect, how would three sockets from the same set all make it through a functioning QC system?
2. These are defects that we can spot visually. Which other defects or discontinuities are present that we cannot see (material properties resulting from variation in the base materials, forging process, or heat treatment)?
For example, if you looked at a welded product where the welder took no pride in their work, and did not clean or finish their product, how much confidence would you have in their internal weld quality?
Zewnten
At least they search the forum rather than starting a new thread for repeat question of a handful of topics.
vssjim
McLean Va.
To me as a tool user and buyer for 45 years Snap On was the best in the sixties through early 80's with a cursive script logo as the wrenches were different then than when they went to the block lettering every thing got thinner and was really hard on your hand so I stopped using them.
f121
UK
QC works by sampling. For example, they make 100k sockets and inspect a random sample of 50, if any fail they then investigate. Sample sizes are picked based on manufacturing tolerances, past performance, acceptable failure percentage and a ton of other variables.
p0rkchop
New York
I bought these new from the website this week and was pretty disappointed when they arrived. Hard to see in the picture but the teeth are misaligned and there’s a gap on one side. Nvm they are all scratched up.
it should make contact on whatever it’s grabbing but as a hobbyist who certainly doesn’t need Snap On I’m a little disappointed.
I wanted to avoid overseas “original” vise grips and people here seemed to like the grip ons so I thought I’d give them a shot from Snap On as they are actually a fair price.
M635_Guy
NC
All of which can/should be set at a high level of QC given the price they set.
I mean, these aren't rustic/handmade leather boots where part of the charm lies in the variability of the materials and execution.
Granted, tools are probably never going to be better than the day you open the box, but for the most-expensive professional-grade tools, that day should be a nearly perfect one. I've got decades of experience in jobs that involved a manufacturing component one way or another that tells me not every single thing is going to be perfect, and in the situation that it's not, I expect them to make it right, not make excuses. In fairness, I don't think SO does anything different than SK did - they make it right. It's people on the internet that want to make excuses.
CHI_Tool&Die
Chicago, IL
The last Snap-on truck I saw was sitting in a parking lot with a giant "For Sale" sign on the window. I don't even see the other brand's tool trucks driving around. I can't imagine it being as profitable as it was with so many mid-level tool companies springing up all over.
JHB
Well, I decided to see if I could actually polish the chrome after removing the oxides/scale.
I used 000 synthetic steel wool with a citrus degreaser as a lubricant, then Auosol metal polish and a microfiber towel to finish the job.
mr.lemons
UK
What brand of wrenches are available without chrome on the inside of the box end?
Never mind, I guess you are referring to industrial wrenches that have no chrome at all.
