I am trying to figure out how to connect 4g wire to 12g wire in house wiring
Situation:
Looks like someone was planning to install a sub panel in the garage, but never finished-
-The sub panel is in the garage wired with both hots to the breaker legs, and has a neutral and ground to there own bus bars. A 20 amp breaker in the sub panel feeds 12/2 romex to power the garage. There are no grounding rods wired to the sub panel
-The 4 4g wires go in to a 1 1/2" PVC conduit that goes to under the house where the wires exit out the end of the conduit and are lying on the ground connected to 12/2 romex with wire kearneys
-The 12g romex goes up the wall and ends at the breaker panel to a 20amp breaker
I do not need a sub panel or 240v in this garage and want to make it safe/to code. I do not think I can pull new wire though the conduit, it has to many bends buried in pretty new concrete down the driveway. I'm guessing 5 90* bends
Plan:
-Gut the internals of the sub panel and just use it as a J box
-Connect a J box to the conduit under the house and connect the 4g wire to the 12g wire in the box
-Leave the 2nd hot wire disconnected in both boxes in case its needed later
How do I connect the 4g wire to the 12g wire correctly?
I was thinking of screwing a 3 wire terminal block into the J box under the house and one in the gutted sub panel box. Do they make terminal blocks that will take 4g wire on one side and 12g wire on the other side? Also, do they make some sort of plastic cover that can be screwed over the terminal block - I was think for extra safety if someone was to open the door to the gutted sub panel and stick there hand in with a live circuit. Or I could put in the breaker cover plate as an extra guard too
Or is a kearney wrapped in electrical tape acceptable in a J box for the hot, neutral and ground wire?
Edit - So I found this to use as a terminal block
www.mcmaster.com
But is it ok to install in a J Box?
Situation:
Plan:
McMaster-Carr
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
