Wilton 4" Vise. $75 "Easy fix".
cmccuist1
Lake Jackson
That is not an easy fix obviously.
I bought this one this weekend for $85 off of FB Marketplace. Just needs a new paint job. The stand is going into the dumpster.
Bucko
Its an easy fix he says bit he don't wanna do it. I guess he's got the right idea on his location of it...right on the trash can.
Shiftless
East Bay SFO
A Wilton bullet for $85 is suckage worthy. It‘s hard to be sure at that angle, but it looks like it might be a combination C series Wilton. If so, double suckage at that price.
Shiftless
East Bay SFO
Get a non-Wilton that works for $75...
That’s my advice as well. That Wilton that 210 posted has been horribly abused and the “repairs” made on the poor thing are hardly repairs at all.
Once a guy learns about the high quality vintage vises that aren’t marked Wilton, he can often find a jewel for a reasonable price. Wilton bullets are priced relatively higher because of name recognition and the perhaps irrational appeal of the enclosed tubular slide design.
Grab an old Reed or Starrett or Athol or Morgan or Rock Island or half a dozen other lesser known brands and use it for the rest of your life.
Packard V8
Spokane, WA
"Easy fix" is guaranteed to be a difficult, expensive, sometimes impossible fix, or the seller would already have done it.
There was a fair condition Holland vise for sale for months on craigslist. "Just needs replacement jaws, easy fix, $25 on the internet." I wrote the guy, "Just put the new jaws on it and I'll give you $50 more than you're asking." Didn't get an answer.
jack vines
Catcher1984
Los Angeles
Is it just the way your vise is pictured or is the base part rusted through where the swivel handles go?
Catcher1984
Los Angeles
Found a C1 locally and it looked good at first glance… but someone welded the back piece together and grinded off the “C1”
crguy
SW Washington
That's why smart buyers are usually suspicious of vises, etc. with new paint. A lot of people have learned that lesson the hard way from unscrupulous sellers.
I bought this vise recently with multiple heavy coats of paint on it just from the picture. Couldn't be sure what the condition was until I got the paint off.
Catcher1984
Los Angeles
Yours looks good, just needs cleaning. Here is a SJ I found locally as well that’s been welded. And both buyers want ~$700 for each of them….
bhohenbr
I too recently found a C1 on FB, mine was a $200 "easy fix" but did come with a table. After tear down, I found the end assembly was broken. Any advice on how to fix it?
Yes, that is snow in the picture. The previous owner left it out in the cold to freeze to death..
Catcher1984
Los Angeles
Hard to imagine why someone would weld that up.
I know but Ive seen more than a few swivel jaw Prentiss vises that have been welded, probably for “stability”.
I think as long as the pins hold the spindle shaft nut in place/secure with the body you should be okay. The end support uses an interference fit along with the pins so it shouldn’t just fall off.
crguy
SW Washington
Hard to imagine a need for more stability. I regularly use my Reed 4" with a swivel jaw, with or without the jaw swiveled. Seems plenty stable to me. After you weld one, you've lost what made the vise "special".
Catcher1984
Los Angeles
I agree, that’s just the most reasonable reason for welding it that I could think of? I think any welding on a vise shouldn’t be allowed expect for repair purposes.
G-ManBart
That's actually fairly common damage caused by being dropped with the jaws at least partially open. The vise goes nose first into the ground and hits the spindle. The spindle pushes backwards on the nut and the pins break out the front of the tail cap assembly.
The best way I have found to fix them is to grind away the material that would normally be behind the pins (technically in front of the pins) and then TIG weld a large washer over that section (Inconel filler rod works best). I often have to change the washer OD and ID to match, but that's easy and it doesn't have to be perfect. I actually like the washer to be slightly smaller in outer diameter so there is a nice ridge I can use to weld along. If you just weld a washer in place without grinding down to the pin holes, the pins will move back and forth and they're supposed to be stationary.
After welding the washer in place I will reassemble the body of the vise with the nut and tail cap assembly, then put the whole thing is a very large vise using a length of round stock or a large socket to press the nut and tail cap assembly into position securely. If not, everything won't be lined up properly. I then re-drill the pin holes, normally going up a fraction...so from 1/4" to 5/16" or something similar. Remove it from the big vise, install the pins, smooth them with a flap disc and nobody will know the tail cap was ever damaged.
The first time I tried this I brazed the washer in place and it worked fine as well. The pins only come into play when you're opening the vise, so they don't see much of a load.
The first time I did this the tail cap assembly actually had very little material behind the pins, so I didn't have to remove much of anything before adding the washer. The pictures are the first time I tried it...flame cut the ID as you can see and then brazed it on the inside...not pretty, but it worked. Now I open the ID on the lathe and also make the OD smaller so I can weld on the outside...just a bit easier.
G-ManBart
I have an extra tail cap and nut from a Wilton 450S that is the same as a C1 nut/tail cap if you don't want to try fixing the one you have.
