Jbullfrog
I am replacing the heater in our Case 1845C skid-loader. The original heater is a Zero-Start that had 90deg compression fittings on the copper tubes so it has clearance to fit where it is at. I got a new identical heater, and when I tried to tighten the compression fittings, it broke the tubes loose where they are soldered to the core. Would a Shark Bite 90 work at the temperatures of a heater core and with antifreeze?
