2 Post lift frame cradle help.
JasonF
Central Mi
I have a Weaver 10k W-pro10 lift that I recently installed. The lift works great but after reading some horror stories of the included flat pads slipping out from under undercoated truck frames I decided I better order the frame cradles. Bad part now is that Weaver is out of stock of the cradles and they don't know when they will have them in stock again. No biggie I figure, I'll just order a set from a different company, but no luck. Turns out the Pro-10 uses sort of a ******* hole size of 38mm when everyone else uses a 35 or 50mm.
Has anyone here found a from cradle from another supplier and made it work with this lift? Or are there any ideas that maybe I'm not thinking about on how to make the flat lift pads safer for framed vehicles?
Jason
infinkc
Would think 35mm ones would work, they will rest on the arms anyway.
J
JasonF
Central Mi
I ordered a set couple months ago for my Atlas lift. They have 1.5"/38mm pins. If I remember correctly they shipped from https://www.uniquetruck.com/
Thank you, I will check them out. How are they working out for you?
Edit- Just did some looking and can't seem to find any frame cradles on that site, by chance would you have a link or a part number?
Nortonscustom
Love them, they work great. Especially when lifting my F150. Mine arrived a little different than pictured. The ones I received have a rubber pad riveted to them.
J
JasonF
Central Mi
Great, the rubber pad would actually be a bonus. I see the cradle is 2.75" wide so I just need to make sure my Duramax frame is narrower than that.
