Amazon Warehouse Deals
Crabman
Alexandria, VA/Dameron, MD
Thanks soloz, a close friend's sister only 56, sad. Gotta go across the Bay Bridge to Salisbury, pretty good drive. My driver is late so maybe a couple more.
United Abrasives-SAIT 22082 Saitech™ High Performance Cut-Off Wheels (Type 27/Type 42 Depressed Center) 6" x .045" x 7/8", 50-Pack​
Regular $138.12, used very good $54.38
In The Doghouse
South of Due West, West of NinetySix in SC
This $15 sander delivered today. All I got was the handle as pictured and a wrench to attach sanding pads. It seems the sanding pads should have been included based on this https://www.nationaltoolwarehouse.com/Complete-Dual-Action-Sanding-Polishing-Kit-P5426.aspx
Can I get the threaded sanding pad attachments cheaply or should I send this back?
vwpieces
Hills, PA
NEIKO 30223A Complete Impact Adapter and Reducer Set | 8 Piece | Standard SAE Sizes | Cr-V Steel | Impact Driver and Wrench Conversion Kit | Locking Socket Adapters | Ball Detent | Square Drive​
67CarGuy
Outside Boston, MA
The Used - Very Good option ($12.41) is still available as of 1:30PM Friday, FYI. I don't need it, but if someone else does...
Crabman
Die Grinder, 1/4 Air Die Grinder Angle Die Grinder Straight Die Grinder Kit Grinding Engraving Machine, 23000rpm Pneumatic Die Grinder​
Regular $34.59, used very good $13.10
Crabman
