general ike
Hey all, absolutely great info on this forum. I have been doing some research on a highlift conversion to give me some room for my four post car lift. I have it mostly figure out, thanks to you all but I have run into a road block trying to figure out my cable length
I plan on using a cable drum D400-54 highlift and I currently have the following:
123" floor to ceiling height
96" high door
107" floor current shaft center
19.5" track to ceiling
I am hoping to bring the shaft to 3" from the ceiling (120" from the floor} and the track 6.5" from the ceiling (117" from the floor) in that I need every bit of clearance I can get. I think I can still get a side mounted motor in the future. My highlift would be 21"if my numbers are correct.
So first off are my calculations correct? I know its tight but will it work?????
I am also trying to determine cable length. I know its not simple and that you want the cable to reach the flat part of the asymmetrical drum just as it goes horizontal on the track so you might need to wind some of the cable before the drum starts moving. I found the following formula:
" Floor to shaft center +63" minus amount of hi-lift" . so my calculations make he cable length 162" long That seems like it would create a lot of excess cable wrapped around the drum? Could this be possibly be correct? It seems like it would take up all the tapered section. It does not seem to make sense.
I could use some help here before I start purchasing parts. So I would greatly appreciate any and all help. Thanks Ike
96" high door
