I started to clean up my Grandpa's Old Columbian 605 vise a about a month ago and just put it back together tonight. I am still not done completely but it will work with the soft jaws i have in it now.
This is the only real before pic that i have of it.
What I wanted to do was to remove the original jaws and make the vise accept removable jaws like my wilton.
So to do this I made a steel piece that will mount semi-permanently in the vice and take bolts to mount the jaw face. So this is what I came up with.
This is the vise with the jaw removed
These three holes had pins that were holding the original jaws in. I later drilled and tapped them for set screws that can be removed from the bottom.
The little T shaped thing is what i made to install into the Vise to accept the new faces.
And finally here it is all finished and painted. I still have yet to make the steel faces for it. I am not looking forward to machining the 4140 i bought for the faces.
It turned out pretty good. I got all of the slop out of the handle too so that is much nicer. Plus that shade of brown was getting old.
