dacan23
RI
dacan23
RI
Supposedly mower ETA ship date is now May, the later the better. Because when they are all sitting around unpurchased in the summer maybe there will be some great promos. My HD is fully stocked to the rafters with mowers ready to go for spring.
d.mcfarland
Western PA
I have that. It works! IDK I'm no hammer connoisseur. I bought it because it was the only smooth face framing hammer at HD.
Yep, that's why I got it. I initially bought a milled face hammer but it works like **** on small nails and for demolition the milled face gets jammed up with debris.
Not sure why all the smooth face hammers are either low end garbage or low weight.
assassin10000
I've got a 2553 laying around and have no need for a 1/4" hex. I'm wondering if I could convert it to 3/8" square, relatively easily.
Like this guy did using the anvil from a 2552 to make his 2553 a slightly more powerful version.
That said anyone got a 2451 and/or 2463 they wouldn't mind disassembling to take some measurements of the anvil?
The diameter of the shaft where it protrudes through the opening.
Length of across the ears.
Height from tip to base.
Width and thickness of the ears.
The hole diameter/depth inside the base.
Still hoping for measurements of a 2451 and 2463 anvil.
Took my 2553 apart for measurements.
IMG_20220211_211016.jpgIMG_20220211_210901.jpgIMG_20220211_210837.jpgIMG_20220211_210939.jpgIMG_20220211_211058.jpgIMG_20220211_211118.jpgIMG_20220211_211234.jpg
Depth is measured to the lip inside the bore. It goes a bit deeper at the center.
Odd-job
I tried this back in the day with an m18 fuel gen 2 hex impact. While the anvil dropped in nicely, ideally I would've gotten the nose cone as the anvil flopped around. DId put an o ring to help minimize the flop. If you need a new nose cone, just buying a 3/8 stubby might make more sense. I ended up buying a 3/8 stubby anyways and gave away the modified hex impact to my dad.
assassin10000
I have a 1/2" m12 stubby already. It's not just the length but also the width that I'm looking to reduce.
I was considering the 3rd gen 3/8" M12 2454 but if I can make a shorter one from a tool I already have... might as well.
The 2553 is rated 1300+ in-lbs (unknown maximum), 5.1" long.
The 2454 is 1400 in-lbs (max), 6.5" long.
I don't have/recall the width but it was probably a bit thicker on the shorter body.
Odd-job
Got it. See where you are coming from now.
Or maybe we both "need" to get the 3/8 right angle impact :)
Rusty67
LA, CA
I have both the 3/8" and 1/2" drive right angle impact drivers. Gotta say, I love them. They don't have the muscle of a typical impact gun but you shouldn't expect them to.
javyLSU
New Haven, CT
You could probably sell the 2553 and get at least half of what you’ll spend on a right angle impact with the current Buy More Save More promo at Home Depot… That’s what I would do.
assassin10000
Hmmm. Well if I run across a situation where I need or want one, I guess I'll get one.
I'll pass. Still want an ultra compact 3/8" impact.
In other news, I ordered an anvil to try my mod with. Hopefully it's measurements are close to my guesstimate, based on online pics of the 1/4" hex version laying on a 1x1" square grid at a parts supply website.
assassin10000
I couldn't find any pics/vids of the 2553 next to a 2454 for a size comparison. Not too surprising as they are meant for different jobs. But I did grab a screenshot of the 2553 next to the 2453 to help illustrate the difference in length
Lengths according to Milwaukee's site:
2553 = 5.1"
2453 = 6"
2454 = 6.5"
That means if my mod works well, it shaves almost 1.5" of length while only potentially sacrificing 8ft-lbs (or less).
Odd-job
Anyone successfully mount a rafter hook to their M12 circular saw?
Tired of putting it on the ground and tripping over it.
Odd-job
Do I need another shop vac?
Actually probably need the dual battery one.
dacan23
RI
Wow 3 different versions, guess they are going full in on the dual battery now after the mower. 109 CFM on the dual battery 9g one, 87 CFM on the single battery 6g one. Oh look at all the fancy accessories which cost a fortune.... Why oh why did I buy a second packout vac this month. Why not make the connection method of the accessories the same as the backpack vac?!?! Why is nothing compatible between any 2 Milwaukee vacuums...
Odd-job
Definitely a good sign of things to come. Wonder how this will stack up to my flex vacuum from a suction standpoint. Hopefully there will be a simple adapter or one can jam 1 1/4 accessories on to the end? Looking closer does anyone else think this is compatible with Flex stuff? The hoses look different...
Milwaukee:
Flex:
purplezr2
Central MN
Milwaukee:
Flex:
I wonder if both are made by Cen-Tec....?
Rusty67
LA, CA
A dual battery vac? I hope that thing has some SERIOUS suction power. I like my new m12 fuel vac because it is quiet. Has enough power for inside the house which is where I'm using it but I'd like something to replace the old standby vac I've got in the future. It is working well enough now but when it dies I want to get something with a bit more juice.
Odd-job
Just connect it to the M18 pump for double suction power.
I was going to say no way m12 has to be weak sauce especially since I don't see Fuel on it. So if the m18 has 480 gallons per hour. This is 9 gallons per min or 540 gallons per hour. This m12 somehow has double the power or the specs are sandbagged on the m18 with some lift involved for example.
Definitely plausible. Why reinvent the hose. Cen-tec seems to be the high quality stuff. VCG youtube channel (if you can tolerate the guy) has some demos on the hose twisting.
Also Belts and Boxes youtube says there is a 0931 has 6.5 hp or 145 CFM so a third tier shop vac. See around the 2:50 mark. Edit - doh that's the corded version, maybe I'll stick with my flex afterall which has "158 CFM".
Also says these are made in the USA.
dacan23
RI
Uh didnt realize what this was on the TN page, its an M12 powered attachement, works with any vac. My friend had that idea 4 years ago, think he should sue Milwaukee.
javyLSU
New Haven, CT
I know I do… now.
Odd-job
That might be the one thing I "need" to get.
dacan23
RI
Yep. There goes my "dont need any more Milwuakee" plan
Hopefully one of you fools has the backpack vac and can tell if it fits on the end of the wand stick nicely. The multi size connection end reminds me of an attachment that came with a shop vac shop vac, if that outer ring is flexible then I may not like it as under a little pressure it flexs too much and comes off.
DerekV
Central TX
I gotta say, I’m a little surprised Milwaukee is leaning into the M18x2 stuff given how insanely stubborn they’ve been about “1 battery only” for so long. Ever since Makita introduced their 18x2 platform I’ve been asking “man, why doesn’t Milwaukee do that?” It makes so much sense. It got to the point where their stubbornness was shaking hands with absurdity and I among others here weren’t afraid to call them out for it…over and over and over and over again.
This thread has to be regularly picked apart with a fine toothed comb at Milwaukee HQ - this is not the first time they’ve followed through with things I’ve only ever seen/heard discussed in this very GJ thread. While I’m glad they eventually get around to listening to their customers, they gotta do better. No one asked for a Gen2 Sawzall or multiple more iterations of bandsaws 🤣 how about WHERE ON GOD’S GREEN EARTH IS THE TRACKSAW? Etc. etc. fill in your 8th annual requested tool here.
Side note: I wonder if the M18x2+ thing is a response to the dumpster fire they call MX Fuel. Perhaps pricing for that will start rooting itself in reality? Either way is fine with me, although I think the modularity (and practicality) of a multi battery M18 system is my preference. *cough read my lips Milwaukee*
dacan23
RI
Some of the new accessories look like the connection type for the backpack vac.
Believe backpack is 1 7/8" but the clip goes in a channel not over a notch.
This is 2 1/2 so doesnt work, but looks rigid and has a notch ring.
Most of the rest of the air tip I think the outer ring is flexible and they supposedly do 2 1/2, 1 7/8, and 1 1/4. But that may work on the end of the backpack wand stick but you can't use any of them just on the hose.
This is like the universal nozzle on an old shop vac, except dont thing the flex ring is removable. In theory it looks great but not so much, will the Milwaukee version be better. Didn't shop vac go bankrupt and someone bought them, was it TTI? I would think this style universal connection is patented.
I am seriously tired of them changing size and type with every new vacuum release. Besides the included 3 accessories on the backpack they have made nothing, now a whole new line & type, but they tried to make it universal, but I only see them fitting the wand stick like I said and you're SOOL if you want to use hose only.
dacan23
RI
Spot on. But they were waiting to give you an M18 x 2 track saw. Makita was right with 18x2, flexvolt doesnt compare, it was the obvious choice as it allows pack size to be maintained for most tools which a giant pack doesnt work.
While they finally listen occasionally at the same time have their heads up their a__. Not mentioned here yet but elsewhere, why isn't this new shopvac line packout compatible. Why make a rolling base when you already have the packout dolly, or would fit nicely on the packout hand cart. Rumor theres gonna be even more versions, a packout one and battery with cord option. Why do you have to make 10 versions of the same shop vac?!?!?!?
DerekV
Central TX
Sounds like a very Milwaukee thing to do if ya ask me
Rusty67
LA, CA
When Milwaukee releases this tool next year, don't expect to get a royalty =-P
Seriously though, nice job with that mod.
assassin10000
Very nice. Clearly this gave you a good excuse to play with a lathe. I see the alterior motive.
so you had to bore out the nose cone slightly?
Ha. No excuses needed. I've got a standing invitation to borrow it anytime I want. Just got to have an idea.
Like making a larger bore hose connection for diy transmission fluid pump.
He's also got a mill. Modded some calipers for a future conversion:IMG_20220112_193803.jpg
Yes. Also spent a little time and made an adapter bushing for the gear shaft. The I.D. of the anvil is larger on the 3/8" square than the 1/4" hex.
Lol. Wish they had already made it.
Thanks. Now to see how well it works.
Rusty67
LA, CA
You are doing some really cool stuff in the shop man. Keep it up!
javyLSU
New Haven, CT
Time to send that guy off to @Torque Test Channel !
assassin10000
Hmmm. Maybe, if they're interested. But I built this to use it and may not want to be without it. :unsure:
I saw the man caver & torque test videos. I just reinvented the wheel as 3/8" drive instead of 1/2". They were definitely the inspiration.
That said it pulled my properly torqued 19mm lug nuts with ease (85 ft-lbs). Maybe easier than my older smaller brushed dewalt 1/2" (I think it was rated 150lbs new?).
turtleman321
Harrisburg, PA
New m18 inflator.
Will be picking one of these up to replace my m12.
Odd-job
New m18 inflator.
finally! This looks pretty big though. This or the m18 compressor?
I guess the m18 compressor doesn't have a set and leave it setting, but I like the fact that its got more versatility to run a nailer and seat mountain bike tubeless tires.
Also trying to figure out how much more air volume this has vs the m12 inflator. The best data points (or lack thereof) I can see this inflates a 33 inch truck tire in under a minute and the m12 inflates a passenger tire in under a minute which was optimistic.
LeeG
Phoenix, AZ
I will get one of the M18 inflators just so I don't have to carry M12 batteries in my truck. I use M12 a lot in the shop, but pretty much everything I carry in my truck is M18 (Impact driver, Drill, Floodlight, impact wrench).
