zr1nsx
For a number of years I worked for a race team in a series sponsored by MAC. We had everything imaginable from them. Tool chests are awesome. Ratchets sucked. Overall, the product is just fair to midland in my opinion.
Picture is made next to an old Craftsman hinge bar (need to clean a little more and will post... One of my 20c very rusty purchases...Beautiful pliers wrench.
I use an extension about that long to get bellhousing bolts off of a front engine rear wheel drive car. The floor pan of the car closely matches the transmission so there isn't room to get your hand in there to get all the bolts, and it is too far under the fire wall to come from above. Coming at the bolts from the end of the transmission with a universal on the socket works. A little bit of extra clearance can be had by unbolting the cross member and allowing the transmission to lower slightly. This puts a lot of strain on the motor mounts so I do it just enough to get clearance.... Not sure what it would be used for though - big trucks?
Have you had a chance to use them yet? I have a couple 3" long bolts that I've been fighting with and I only have access to swing my 90 tooth ratchet held by my finger tips 1-3 teeth at a time. I've been trying to think of other ways to get them off and these things came to mind.
Lots of MAC stuff is just rebranded. Especially the pliers. My Knipex Cobras are also MAC branded and I have no real issue with that. No point with them trying to compete with Knipex. They charge a slight premium over buying Knipex directly but you get the MAC warranty service in exchange.
I have, as well as the Snap-on equivalent. I find these are much smoother and take impact wrenches much better. You just have to remember to open them up periodically and grease them.Have you had a chance to use them yet? I have a couple 3" long bolts that I've been fighting with and I only have access to swing my 90 tooth ratchet held by my finger tips 1-3 teeth at a time. I've been trying to think of other ways to get them off and these things came to mind.
Question, what are these used for?
Interesting, thanks
You saved me a whole bunch of typing, thanks!
When I was selling Snap On tools we referred to Mac dealers as "Mac Toils".It seems to me that MAC is somewhat unpopular on GJ (except for toolboxes). As with each company, there is good, there is bad. Same as with our current world. Lets concentrate on good...
Lets share our MAC tools. I decided to post it here instead of the vintage tool thread as even though older MAC tools are all USA made and mostly good quality, there are some modern tools as well which are great as well. MAC tool boxes, carts, etc are welcomed as well.
I will start with some old and some new
...Not sure if the 4th wrench (7A) is factory bent like this or PO bent it. Please let me know if you have/saw one like that...
That brings back memories from...1992-ish.Sure looks like a IR gun.
Those metric door wrenches are the "BOMB"!
My one and only Mac tool… I’ve found myself with such a pieced together smorgasbord tool collection that I’m trying to have at least one of every major, and some minor, brands that have been sold in the last 100 years. So far I have a pretty well rounded collection and this wrench happens to be the one Mac Tools item I own. Cheers!View attachment 1611568
My one and only Mac tool… I’ve found myself with such a pieced together smorgasbord tool collection that I’m trying to have at least one of every major, and some minor, tool brands that have been sold in the last 100 years. So far I have a pretty well rounded collection and this wrench happens to be the one Mac Tools item I own. Cheers!
My bad.. thank youI suggest cropping your photo so folks don't get the wrong idea about your "one major and one minor tools".
I was using a Blue-Point (AT500BL?) extended-anvil "Tire shop" air wrench at the time, and in the market to move up--needed More Power. The Mac Man had the AW434 on promo; and I almost almost almost bought one. It had the scalloped handle like yours, so it wasn't the original '434; it may/may not have been the 434M. I did buy a Mac die grinder, and the pair of Mac 3/8 and 1/2 reversible drills. I found out decades later that the die grinder was sourced from SP Air; (Japan) the drills were sourced from Viking (USA). Still have the grinder and drills; they've had minimal repairs and still work great after 30 years. (Two pair of bearings in the die grinder; some trigger work and a chuck on the 3/8 drill; and a hateful fight to find a reverse-thread chuck screw for the 1/2-inch drill (and it should have the trigger/valve looked at.) Viking has discontinued that series of drill; and they aren't stocking parts for 'em either. SP Air is still providing essentially the same die grinder, though.
Decades later, I'm in the market for a secondary air wrench; and again almost bought a (used) 434. I did some research, figured-out is was almost certainly a Mac-branded version of an IR. The handle shape isn't right for a 232 in that the (current) 232TGSL has the scallop/swoosh/flare on the left side of the handle while the right side is plain, yours has one on the right (L and R as seen from the rear.)
Might be a customized version of the 244; but again the handle shape isn't exactly right.
The aluminum/steel IR impacts tend to have the case halves screwed together with three fasteners. The common IR231 has two fasteners high on the tool, and one low, just above the trigger. The 232, 244, and the Mac 434 have one fastener at the very top, and two lower-down.
In the end, I wound up with an eBay Snappy IM6200 with the air-directing valve for low-noise (muffled) or full-power (muffler bypassed.)
