Spacep0d
Got a new garage fridge installed, new Gorilla ladder added, found the studs needed for my WallControl pegboard installation.
Is it a cold weather fridge or are you lucky enough to live in a warmer climate?Got a new garage fridge installed, new Gorilla ladder added, found the studs needed for my WallControl pegboard installation.
Will do! Just was futzing with “something” to kill time until the deputy arrived.@Magnum440d100 , you might want to consider soaking those pliers in Evaporust for a few days to clean them up, too.
Regular fuel station diesel nozzles are the same type and size. They sometimes have a different color wrap on the handle. I work with a gentleman who put gas in his new diesel truck. Oopsie!
Dealt with this lol. Customer states they have oil leak in driveway and uses two quarts of oil every month. Drain plug had no gasket and was finger tight. I told them about it they said their son changed the oil. Judging by how dirty this car was it’s a wonder you could even know it was oil leaking haha. I spilled a bit of washer fluid and looked down and thought it was like the orange GM coolant or rusty water but it was the dirt falling off this car. They said if it’s not leaking around the filter or drain plug don’t change the oil because we will have the Mitsubishi shop do that. We had to special order a gasket even though Mitsubishi is one of our franchises we don’t stock the copper washer type gaskets for them. Only reason it was dispatched to me is because it was a waiter and the two Mitsubishi guys were busy. I cleaned off the oily area with brake clean and put oil in it and sent it just what the boss said to do lol.
Also done a wheel stud and lug that snapped off on a Subaru Legacy. I was happy to do that because I wanted to use my extra long Husky ratchet it done great. And had to do a complete fuel system flush and somewhat pretty much rebuild a Subaru Forester fuel system had a customer put diesel in it instead of gas. I feel bad for them said they had never had to do it before is what the advisor told me. I thought the diesel nozzles were a different size than gas to prevent that from happening but it’s not all of them that are different sizes I guess. I replaced the plugs, injectors, flushed the fuel tank and used lots of fuel system cleaner, cleaned the lines. I spent practically all day doing that because I got it all together and it still would not fire for anything had to take the plugs back out and clean the ends as they were getting diesel residual on them still. Customer declined new fuel lines, pump or tank otherwise I would of done those too. Finally got it to fire up and then drove it around about 40 miles to make sure everything was good. I had fun doing that when I seen that in my bin and on my computer screen as assigned I was excited lol. They said this is one exception that you can drive it longer than an allowed test drive and you can take it past the test drive route if needed. So even though it kicked my tail a little bit with the plugs I got it done and am happy with it. It will go to the customer tomorrow. Good thing we aren’t flat rate anymore or I probably would of lost money lol. The customer had filled it up and it done ok but run rough then died and would not start back up and they kept cranking it with the diesel in it. So it probably was mixing with the gas at first then the gas completely ran out leaving just the diesel in it is my guess. Just glad the issue is fixed now hopefully.
That was the best day I have had in a long time I love big jobs and we seem to be picking back up so it’s always good news to hear that. Now if we could get certain parts we would be doing excellent.
No kidding! I'm just glad he didn't include a link also.......I can think of a bunch of useful places for that mat.Damn you. Why do you keep helping me spend my money. Now that I've seen that mat I have to have one as well. Last week it was the skids. You need to quit posting so much of your cool **** as my wallet can't take it.![]()
I used to put stickers on my first box. Now they go on the trash can.What I did in my garage. Part TWO lol
I had some plans that got canceled on me. No worries, as I REALLY didn’t want to be out in this weather.
So, I spent more time in the garage.
Got my grampas tools in his boxes. That cleared a cardboard box off the ground and out of the way of walking. Unpacked a couple more totes and found the tote with the hood hinges for the 72 dodge (pictured). So got the hood cleared of **** in anticipation of installing them.
And something I’m not entirely proud of, except out of necessity. My upper box took a beating on the trip out here. And got a bunch of scrapes down to bare metal. No dents thankfully.
I had a bunch of stickers laying around. So they went on the box. Can’t even tell where the beat up parts are! Hahahaha
Still haven’t cleared the work bench entirely
It’s dinner time now.
Until tomorrow!!!
BP handles in green can be confusing if you are not a regular BP customer. To be fair they have been using green on their handles long before diesel cars and trucks became popular, after all green is their corporate color. I had a diesel powered 1981 Toyota pickup truck and I had to stop and think about which pump to use when I stopped at BP. The good part was that there was a gas crisis around that time and long lines at the pump was the norm, no waiting at the diesel pump.Regular fuel station diesel nozzles are the same type and size. They sometimes have a different color wrap on the handle. I work with a gentleman who put gas in his new diesel truck. Oopsie!
Most stations use green handles for diesel, but BP uses green for gas!? A real head scratcher. Some other stations also utilize yellow handles for diesel. Now big semi sized fuel stops have larger diameter fuel nozzles in the semi pull thru bays.
The hubs showed up today.
Ran errands this morning. Now got the Dakota in the garage with the heaters going, to help dry it off so I can work on it “comfortably” lol
Plus letting the hubs warm up so I can paint them. Hopin that helps keep the rust “at bay”.
So most likely not gonna be swapping hubs till tomorrow. But I DID pick up some hardware so I can attach the new heat shields to the exhaust manifolds. Again, just awaiting the warmth lol
Decided to start early. Got 2 bolts out. Snapped the third. Drilled it out, but the hub is rust seized on there.Good luck with those. I did the hubs on my 01 a couple years ago. Broke one breaker bar getting them loose. An air hammer will help once you get the bolts out. Not a lot of tool clearance to work with on the back side.
Have you ever tired the knock a stud out and use a pusher bolt method? >Decided to start early. Got 2 bolts out. Snapped the third. Drilled it out, but the hub is rust seized on there.
No air hammer or air compressor right now unfortunately. So I’m gonna have to pop the spindle off and see if the 20T press can push the hub out.
Called it a night, and got on the interwebs to order a replacement bolt. The Dakota is my only driver right now. So I can’t just hop on down to the hardware store :/
I have not.Have you ever tired the knock a stud out and use a pusher bolt method? >
What is up with your Ram ?Decided to start early. Got 2 bolts out. Snapped the third. Drilled it out, but the hub is rust seized on there.
