I'm not sure where you're going with this. The stiffness of steel (Young's modulus, the propensity to resist deflection) is effectively independent of hardness. It's a property of the steel composition and geometry. The fit of the tool on the fastener determines the geometry of the interaction and a tighter fit will mean that a greater deflection of the open end will be required prior to the wrench slipping. A well heat treated piece of steel like these wrenches will deform elastically in this case and not take a set. When the wrench spreads and rounds a bolt the wrench doesn't end up plastically deformed with the jaws no longer parallel.Appreciate the thread and resources required to put it all together. I personally would have liked to see if there was any change with the open end measurements after the test. In theory, unless it’s just the butter the wrench hardness should supersede the fitting. With that said.. I’ve junked or put in the warranty box my fair share of line wrenches due to visible spread.
Just a thought..
I suppose I’ve owned some steel that wasn’t “well treated”, Because they have definitely taken a “set” over the years.I'm not sure where you're going with this. The stiffness of steel (Young's modulus, the propensity to resist deflection) is effectively independent of hardness. It's a property of the steel composition and geometry. The fit of the tool on the fastener determines the geometry of the interaction and a tighter fit will mean that a greater deflection of the open end will be required prior to the wrench slipping. A well heat treated piece of steel like these wrenches will deform elastically in this case and not take a set. When the wrench spreads and rounds a bolt the wrench doesn't end up plastically deformed with the jaws no longer parallel.
Hard to say. This one just 'happened' to confirm the popular opinion that Snap On is the best. There are plenty of video from TTC that does not. Like a junky brand on Amazon 1/2 impact wrench is same as a Ridgid. I have a full set of the type of China-made Cman flarenut wrench as tested here and I am very happy. No need to consider SK at least. I am in California, there is definitely no need for me to buy more expensive stuff.Could you imagine if project farm did this comparison?
Is the wrench spread permanent seems like a logical question.I suppose I’ve owned some steel that wasn’t “well treated”, Because they have definitely taken a “set” over the years.
I didn’t realize I was trying to “go” anywhere crazy, it was just a simple question and observation.
my experience in 30 years of using them says otherwise .I'm not sure where you're going with this. The stiffness of steel (Young's modulus, the propensity to resist deflection) is effectively independent of hardness. It's a property of the steel composition and geometry. The fit of the tool on the fastener determines the geometry of the interaction and a tighter fit will mean that a greater deflection of the open end will be required prior to the wrench slipping. A well heat treated piece of steel like these wrenches will deform elastically in this case and not take a set. When the wrench spreads and rounds a bolt the wrench doesn't end up plastically deformed with the jaws no longer parallel.
It looks like the wrench size is what's mattering here. Not just the wrench spreading.
We have comments about this too. We used the smallest size who's threads weren't the weak point. On a 10mm or 3/8" hex bolt, the thread size needed is tiny. You end up killing threads on a small soft hex nut way before learning anything about the wrench. 9 out of 10 wrenches max out the threads, nothing to measure there. That lesson cost us a few hundred bucks lol.Thats the only area I wish we could have seen tested.. Wish instead of doing the 1/2" - 9/16" range they could have added the more common brake line fitting sizes (8/10mm 3/8-5/16). Would have been an interesting comparison to see if the smaller sizes experience the same "issues" as the bigger sizes. For DIY those are probably more commonly found/used sizes too.
Still cant complain on their test though! Was interesting to see how everything performed.
Thanks for the explanation. I was also wondering why you didn't use bleeder sizes.We have comments about this too. We used the smallest size who's threads weren't the weak point. On a 10mm or 3/8" hex bolt, the thread size needed is tiny. You end up killing threads on a small soft hex nut way before learning anything about the wrench. 9 out of 10 wrenches max out the threads, nothing to measure there. That lesson cost us a few hundred bucks lol.
Its also not only about hex tolerance. It's a good piece of the pie however.
You can usually put a box wrench on a bleeder, and being a closed ring, even a cheap box wrench will likely outperform a Snap On flare nut wrench. Plus box wrenches will be thinner wall.Thanks for the explanation. I was also wondering why you didn't use bleeder sizes.
The lines on some power steering boxes are designed in such a way as to give a grown man fits...(or prompt fits of cursin') LOLTrue. Its more like brake LINES than bleeders requiring flatenut wrenches.
Thanks for a very interesting and informative test - did you measure the tolerance/spread after the last test?True. Its more like brake LINES than bleeders requiring flatenut wrenches.
I have a set of 6pt box end wrenches I bought just for bleeders. Sometimes I get lucky and they even work on rusty ones.You can usually put a box wrench on a bleeder, and being a closed ring, even a cheap box wrench will likely outperform a Snap On flare nut wrench. Plus box wrenches will be thinner wall.
I have irreparably spread a 10mm flare wrench before; its not tightening that's the problem, it's trying to loosen a steel nut that's been in an aluminum block for 15+ years...We have comments about this too. We used the smallest size who's threads weren't the weak point. On a 10mm or 3/8" hex bolt, the thread size needed is tiny. You end up killing threads on a small soft hex nut way before learning anything about the wrench. 9 out of 10 wrenches max out the threads, nothing to measure there. That lesson cost us a few hundred bucks lol.
Once busted loose, or when assembling, 12 point flare wrenches are also an option. I made some out of Harbor Freight combo wrenches for the specific task of assembling the power steering on a 64 Studebaker (think GM style ram PS) I would definitely use my Snap-On for breaking loose though!A point that many of the posters are missing.
Is the DESIGN of the Wrench.
The engagement surfaces of the SNAP ON Wrenches is closest to being flush. Much less "lead in" taper than with the other makers.
This allows the SNAP ON Wrench to engage more of the fastener.
Many times, these fasteners are pitifully shallow, and a wrench from "other makers" has so much "lead in"...that it will barely engage the top of the fastener....
If one were to hold the wrenches side by side....this is readily visible...
I have a set of Snap On & a set of MAC line wrenches (some others in the "mixed wrench drawer") for the simple reason that the "index" is different. In a tight spot, loosen the fastener the first little bit with one (or the other) then switch to loosen the next little bit with the other brand.
Many areas around hydraulics do not permit a SIXTY DEGREE "swing" of the wrench.
The fasteners that can be readily loosened with these two brands of line wrenches is amazing. Compared to the amount of fasteners that can be RUINED using other brands of line wrenches.
My third choice in line wrenches would be the KD brand...used to be handled by the local parts store....(not sure if they still make those?)
I pick up 6 point box and combo wrenches whenever I see them cheap. Mostly RP Craftsman but as you say still better than 12 point or flare.I have a set of 6pt box end wrenches I bought just for bleeders. Sometimes I get lucky and they even work on rusty ones.
I have 1/2" to 3/4" Snap-on wrenches in 12 point that are great to use in tight spots but for really tight bolts they will slip. The 3/4" one I use the most for injector lines. Usually they're not too tight and 12 points makes it much easier in tight spots.Once busted loose, or when assembling, 12 point flare wrenches are also an option. I made some out of Harbor Freight combo wrenches for the specific task of assembling the power steering on a 64 Studebaker (think GM style ram PS) I would definitely use my Snap-On for breaking loose though!
Why use flare wrenches for bleeders?I love my Snap-on and they haven't rounded off bleeders yet. Rounded off several using Tektons. Had to buy a Proto 8mm since most Toyota's I've been working on had 8mm bleeders.
My thought exactly, just use a box end.Why use flare wrenches for bleeders?
I live in Illinois so the go to brake line tools are a pair of visegrips, torch and snips. It's pretty rare to get a fitting loose unless it's pretty new.
Have a set of Cman RP and SK line wrenches. As a DIY'er, I'd take both, use whichever fit the tightest.. Recently picked up Knipex flare nut pliers. I'll be doing some brake work on the avatar this spring, we'll see if the Knips were money well spent.
There ya go, the Torque Test Channel can test the various anti slip open ends found on combination wrenches such as wright grip, Proto ASD, Carlyle, Harbor Freight, Gearwrench, MAC precision Torque, Snap on, and even the new Die Hard.@Torque Test Channel
It would have been interesting to see how the FD+ open end performed in this test.
