I have chronic RA so the clutch lever on the bike is too heavy to use comfortably, so I put the law of the lever to work.
The clutch lever's distance from pivot point to ****** centre is 30mm, whereas the clutch actuator lever's distance from screw, or pivot point, to ****** centre is 35mm, so the law of the lever is already at work, but not enough for me.
I had an old clutch actuator lever that came in a box of parts with the bike. I removed the original lever, cleaned up the damaged screw and turned down the head of the screw to 13mm.
After fashioning a rough lever I attached it to the screw, turned up a dust cover and welded everything together. As I wanted better leverage I drilled the pivot point for the ****** holder 10mm further out from the screw, 45mm.
Attached everything and pulled the lever, much, much better. The actuator lever, due to the increased distance between screw and ****** holder pivot actually moves the pushrod less than the original, but still separates the plates enough for the clutch to do it's job.
