67carl
I finished assembling my bandsaw, even though most of the hardware is metric (but not all, so that is kinda screwy). I only have metric sockets, so for nuts/bolts I used crescent wrenches and vice grip locking pliers. But there are set screws that hold in the blade guard blocks. Those are hex head and I didn't have those wrenches in metric, so I used an SAE one that was close enough
It worked getting them in, but now when I needed to adjust the screw the wrench is a bit loose. I didn't want to strip the hex opening on the screw so I stopped and went to HF to got some metric wrenches. But what I really want to do is replace those screws with a knurled set screw so I won't need a wrench. So I knew it took a 3mm hex wrench to remove it, but I needed to know what OD size of the screw. I found that number is either 5.91 mm, or 25/64 inch. Or would the screw size be determined by the size wrench I used to remove it (3mm). That seems unlikely. I'm going to take it to the hardware store and I'm sure will get it straight, but just thought I'd post here and see what you all think.
These are the screws
What I want to get
What I want to get
