Hoorn
Picked this up yesterday. Far and away the heaviest bench top drill press I've ever had to move around. Having had no prior experience with a South Bend Lathe Works drill press I was quite surprised at some of the innovative features. This early 1950s drill press actually had a factory installed light inside the head with the motor on/off and light switch mounted on the side of the head.
Note the adjustable belt tension lever. (Which also has a hole for chuck key placement)
When the lever is raised all the tension is released from the belt and the horizontal motor mount tilts forward.
Just about the coolest looking pulley out there. Cast aluminum also, not ultra brittle Zamak.
This is a rather unique spindle lock. I thought maybe the handle was lost and someone added the Phillips head adjustment screw, but that's how it came from South Bend. With the screw turned it pushes against a curved shoe that locks the spindle quite securely.
After removing the spindle assembly and the front South Bend badge I was able to take this picture to show the factory mounted light assembly.
South Bend was very proud of their work light.
Here is the wiring for the motor on off switch and the light on off switch. Normally this would be two toggle switches on the side of the head but this particular drill press was heavy on the accessories. In this case it was a Cutler Hammer push button switch box (already shown in the first picture), with the light switch factory mounted on the front of the receptacle box. This model also had the pulley guard and 4 handle "turnstile" feed handle. As for the feed handle, two of the handles were missing and of the remaining two, only one had an intact Bakelite knob. You may also note two electrical cords coming from the drill press. A PO had installed a three-phase motor on this drill press. I can only assume because I bought it from a machine shop that it was for continuous duty. The circular receptacle box behind the Cutler Hammer box was added by a PO and rewired to facilitate three phase wiring. The light was then run solo with its own dedicated electrical cord.
