Amazon Warehouse Deals
D
Duker
Livingston, TX
Sungold Abrasives 87402 Plain Backed Edger Sanding Discs For Floor Sanders Heavyweight Silicon Carbide Paper With 7" X 5/16" Center Hole & Slits (50 Pack), 36 Grit​
D
Duker
Livingston, TX
D
Duker
Livingston, TX
HPS Performance 7/8" ID Clear high Temp Reinforced Silicone Heater Hose tubing, 10 feet Length, Max Temperature Rating: 350F, Bend Radius: 4" (HTHH-087-CLEARx10)​
D
Duker
Livingston, TX
Marathon H682 48Y Frame 5KH32ENA443X Open Drip Proof Carbonator Pump Motor, 1 Split Phase, Rigid Base, Ball Bearing, 1/3 hp, 1800 RPM, 1 Speed, 115 VAC​
D
Duker
Livingston, TX
Parker 169P-4-6-pk20 Compression Fitting for Thermoplastic and Soft Metal Tubing, Poly-Tite, Tube to Pipe, Brass, Compression and Male Pipe 90 Degree Elbow, 1/4" and 3/8" (Pack of 20)​
D
Duker
Livingston, TX
Thanks Duker. Were you sick or something?
Just sick of work! I have been gone every weekend since January, one was to a hammer forging class and one to my daughter in MO to help rip out a guest bath... First weekend back in the shop and I froze my knickers off as my dad would say....!
vwpieces
Hills, PA
Drill America Q/T29J-CO-SET Cobalt Drill Bit Set in Metal Case, 1/16-1/2 x 64ths​
amazon.com/Drill-America-T29J-CO-SET-Cobalt-Metal/dp/B01BM3N8FW/ref=sr_1_197?keywords=impact&qid=1646167496&refinements=p_8%3A60-90%2Cp_6%3AA2L77EE7U53NWQ%7CATVPDKIKX0DER%2Cp_76%3A1249152011%2Cp_n_condition-type%3A6358198011&rnid=6358194011&rps=1&s=hi&sr=1-197
vwpieces
Hills, PA
Irwin Industrial Tools 10234CB #4 Unibit 3/16- Inch – 7/8-Inch, 12-Steps Cobalt Step Drill Bit (1/16- Inch Steps)​
amazon.com/Irwin-Industrial-Tools-10234CB-Unibit/dp/B00126J1PG/ref=sr_1_273?keywords=impact&qid=1646167687&refinements=p_8%3A60-90%2Cp_6%3AA2L77EE7U53NWQ%7CATVPDKIKX0DER%2Cp_76%3A1249152011%2Cp_n_condition-type%3A6358198011&rnid=6358194011&rps=1&s=hi&sr=1-2731646167753984.png
