New tool day - Makita impact
alinc100
Dearborn,MI
We need to know model number. mid range, torque specs, new model, old model, hog ring or pin detent? LOL I have Makitas in 3/8" and 1/2" I've not had issues with the 1/2" and properly torqued lug nuts on my Honda. The only car I work on. When I was working in a shop that we did a lot of teardown on LARGE Dana axles the 18v Milwaukee was a beast. But that doesn't happen at home, and I have no Milwaukee 18v tools.
Snapped-off
Indiana
That's the newer brushless mid torque. Should be XWT17.
K
klassenl
Southern Alberta
DTW700 is the model here in Canada. It's "rated" at 750 ft lbs in reverse and 500 forward. I did a quick test on the lug nuts on my minivan and I already wish the friction ring had a little more friction.
alinc100
Dearborn,MI
I have the XWT11Z BL™ Brushless Motor delivers 210 ft.lbs. of Max Torque and 295 ft.lbs. of Nut-Busting Torque • Compact and ergonomic design at only 5-3/4" long • 3-speed power selection switch (0-1,600 / 0-2,100 / 0-2,800 RPM & 0-1,800 / 0-2,600 / 0-3,500 IPM) for precise fastening control in a wide range of applications
and the 3/8" Sub Compact: XWT12 : Brushless motor delivers 130 ft.lbs. of Fastening Torque and 230 ft.lbs. of Nut-Busting Torque
