jar944
Yes, the lenox is a thincker blade more for a sawmill cutting down wood for millwork, siding, and flooring.
Lenox woodmaster CT
It has a backing .035" thick compared to the resaw kings .024". Also the kerf for the varible 2/3 tpi tooth is .065" on the lenox vs .041" thick on the resaw king. The varible tooth is important if you are doing veneers as rougher cuts mean a planer trip or you sand to much and get uneven thickness, either way waste wood.
The resaw king is wonderful for verneers or recutting. It has better quality finish than a lot of cheap ripping blades on a table saw. It has a finish that only needs sanding which is important in veneers, and with the reduced kerf means you can get an extra slice out of a two inch board if cutting 1/8" veneers compared to the lenox, two if cutting thinner. Like sticking a twenty in your pocket if cutting birdseye or flame maple or other expensive exotics.
I run a 1.3t 1" woodmaster CT. It's fantastic as a resaw blade. I have thinner kerf blades, none cut as well as the woodmaster.
