Pliers - Must Have Pliers & Brands?
sparky 1971
Central Iowa
I guess the other option is forget Knipex all together and just get like two Channellock 420s lol. I suppose it’s not as elegant as the Cobras and Pliers Wrench though.
So if I went the Knipex route…2 10” Cobras and maybe the 7” Pliers Wrench…hmm
Channellock 420's are really good pliers. It's probably been about 15 years now, but Channellock changed the design and made them thicker. I don't care for the new style, but since you've never used the old style, you wouldn't know what you're missing. Same with the Cobra's. If you've never used them, you'd think the 420's were great, which they are, just not as great as Cobra's or the old style 420's.
C
CC268
Well thanks for the help. I’d sure save myself a lot of money by going with a set of 420s. And for home use that’s realistically probably all I “need”. I don’t mind spending the money on the Knipex Cobras and Plier Wrenches, but it is something to consider I guess.
General Geoff
Allentown, Pennsylvania
Channellock 420s would be a poor substitute and compromise of the Cobra and Pliers-Wrench capabilities.
The best features of the Pliers-Wrench are its smooth jaws, and its cam action which keeps the jaws parallel as they open and close. The best feature of the Cobra pliers is that once the teeth bite into what you're trying to turn, the pliers are self-tightening; that is, the harder you push down on the pliers, the tighter it grips, so no need to squeeze with hand force to keep it from slipping.
The Channellock 420 has none of these attributes.
sparky 1971
Central Iowa
All I use around the house are 420's and occasionally 430's. I use Cobra's at work, but am too cheap to buy any for home use. That's what my old Channellocks are for.
sparky 1971
Central Iowa
The 420 does grip down, not as well as Cobra's, but anyone with a decent amount of hand strength can crank on them without any slippage. They aren't intended to be used in the place of a pipe wrench anyway. I used 420's exclusively for about 15 years. I did make the change to Cobra's, but it was more about the fact that I can adjust them and they stay that way until I decide to change the setting.
The pliers wrench is a poor substitute for the proper sized wrench or socket/ratchet. I have a 10" that I just had to have, but it's nothing more than a glorified Crescent wrench that's easier to adjust.
General Geoff
Disagree there. It is a phenomenal tool that in my experience has proven superior to a "correct" sized open end wrench for tie rod adjustments and any plumbing work that has flats on the fittings. The smooth jaws don't tear up the finish of chrome finished plumbing fixtures like a pipe wrench. It is also an outstanding tool for sheet metal bending and shaping.
If you don't want yours anymore, I'll pay you $40 shipped for it! I can always use a spare.
sparky 1971
Central Iowa
I'll pass. Some day I might actually use it and discover that it's as fantastic as everyone on GJ says. Just because I haven't found a use for it in three years doesn't mean I won't. As far as the OP is concerned, he's an average Joe homeowner. He's been getting by with Harbor Freight tools, so anything will be an upgrade.
KnurledNut
n/a
Well I think I’ve settled on my final order:
Klein D203-8 Needle Nose
Klein D2000-28 Diagonal Cutters
Knipex Plier Wrench 10”
Knipex Plier Wrench 7”
Knipex Cobra 10”
Knipex Cobra 7”
I imagine this would cover most of my needs. Would probably look at Klein/Channellock for anything else going forward (pliers)
Advice given here is always biased to that individuals uses. One person may use the heck out of their pliers wrench (like me) and the other guy questions why he even bought them.
The more we know about YOUR intended range of use, the better the suggestions.
With the experience I have acquired over the years, if I was in your shoes, there are some changes I would make to your list:
1. Hang on to the pliers you currently have. They will supplement your new ones, and can be re-purposed. Even cheap linemans can be robust for heavy duty bending, etc. Same goes for your cheap T&G. The diagonal cutters could be ground down for a budget friendly set of flush cutters for zip-ties.
2. The 203-8 is a great tool, but upgrade to the 203-8NCR.
The added 12ga stripper and crimper can be super handy and the tool takes up the same real estate. If you dont have wire strippers, maybe consider even jumping up to the J207-8CR. Any of these still function just fine as long nose pliers.
3. I would get the 2000-48 ANGLED diagonal cutters instead of straight listed.
4. The Pliers Wrench is an amazing tool. However, I would hold off on the 10” and just get the 7” for now. If it proves useful for you, the bigger size can always come later. If you have a good adjustable wrench, possibly put the PW’s on the back burner all together.
5. Get the Knipex Cobras, or possibly consider Alligators if you need the savings. The advantages versus CL are worth it. I think the 10” and 7” are a good choice and gives good versatility. Two 10” will limit you a little, and you could always use your existing T&G (10”?) as a backup wrench. That being said, i use 10” and 6” the most, but my situation is different than yours.
6. Many of the members here have years of experience in a vast array of occupations. The advice is well-founded. Many also have extensive tool sets acquired over years, not overnight.
Unless you are in a dead run to upgrade your tools, possibly consider taking your time and purchase as bargains come along. If you have the time to watch, the used Warehouse Deals on Amazon can be a great source.
Ton ton
Page County,VA
I would recommend you buy your pliers @ a brick and mortar location. This way you can feel the balance of them before you buy. If the grips don't feel right, simply lay them back on the shelf and walk away.
Iridium rand
Now I am just torn on comfort grip vs dipped. Seems like the vast majority of people prefer the slimness of the dipped. That said, if I'm gonna pay for Knipex I'm leaning towards the comfort grips.
Their comfort grips are excellent and I go with them whenever it’s available on the particular pair, can understand the slimness but that also means it’s a little harder to put a lot of force on them since they dig into your hands more
Ton ton
Page County,VA
I don't have experience with channel lock comfort grip. One garage journal member complained about pinching his hand with the comfort grip.
C
CC268
Thanks for the feedback. I really do love this forum - it is very helpful. That said, you could really drive yourself nuts by listening to every opinion. You'd change your list of tools every 5 minutes haha. At some point you do have to just pull the trigger and realize this isn't the last time you will purchase tools. I still think my original list provides a good "base" and I can easily add more to it any time I want.
Regarding your points:
2. I actually prefer the 203-8s. In fact, I'd rather have a set without any cutters at all like Snap On makes, but I'm not going to pay $52 plus shipping for those. I have two very nice wire strippers as I used to do a ton of electrical stripping, soldering, etc when I was into building large RC models and drones. I did a TON of 12 and 14ga and some even larger wire stripping for those things.
3. I'm not completely following you here - these are angled?
4. Not a bad point and I've heard the 7" is the most useful for most folks.
5. I'm going to stick with the 10" and 7" Cobras like you said. I can add a second set whenever if I feel that it is warranted
6. I didn't want to seem as if I was coming off with a strict budget here. In the grand scheme this tool purchase is very minor compared to what I've spent on many other hobbies haha. I really don't mind paying the money for decent quality tools, within reason. I also realize I am not a professional "tool user" and there is a point where it doesn't make sense to pay for Snap On tools when they will likely be used a few times a year. I do have a nice fishing boat and I grew up racing motocross, so I used to wrench on bikes a lot. I no longer own a bike, but I will likely by one again some day. I've been wanting to build a nicer tool collection for years, and now that my wife and I bought a new build home I have the opportunity to gather more tools (it will have a 3 car tandem, so I will have a lot more space than I have now).
All that said, I went ahead and just placed the order:
Knipex Pliers Wrench 10"
Knipex Pliers Wrench 7"
Knipex Cobra 10"
Knipex Cobra 7"
I went with the regular grip - the more I thought about it the more I realized I didn't really want the comfort grip. I actually have a pair of Irwin Needle Nose with the comfort grip, and while they are nice, I agree with most folks that the comfort grip is just a little too bulky. You lose a little dexterity with the tool in exchange for comfort. I can always sell anything above I don't use (that said I really don't sell my tools once I have them - generally). I can add another Cobra or Pliers Wrench if I find the need to.
I'm going to run to Home Depot to get my hands on the Klein and Channellock Needle Nose and Diagonal Cutters as they have both.
Thanks to everyone for all the help! It's been fun.
Davefr
OR
Snap on needle nose are at least $55 of amazing, making them an excellent value.
Agree. I'm not really a SO fanboy but their Talon Grip 8" needle nose are outstanding. The talon grip serration pattern give you excellent grip in all different angles, the grips are tough yet not hard plastic like other pliers, the beveled tips give you access into some tight/confined locations. I would eliminate one of the other pliers from your list if budget is a concern. (IMHO the Klein 203-8 come in at #2 and Doyle/Tekton at #3, Channelock is #4)
Everyone's needs are different but my SO talon grip needle nose never leave my workbench. Same with my 10" Knipex Cobras. However my pliar wrench's and 7" Cobras rarely get taken out of my toolbox.
sparky 1971
Central Iowa
Good call. I had my head up my rear once and accidentally bought a set with the stripping hole and crimping die once at the supply house. The stripper is only a #12, and with the hole right in the center of the cutter, makes it a pain to actually cut. The handles aren't long enough to get enough leverage to crimp the #10 and #12 crimp sleeves consistently. Sure, they will work for a splice or two, just like they will work to strip a wire or two. Nothing will take the place of real strippers and real crimpers.
3. I'm not completely following you here. These are angled.
The head of the dykes you want is cut at an angle. The dykes in question have a "bend" in the handle. I have that style also and use them exclusively when I am doing residential wiring. The bent handle acts as a fulcrum for pulling staples out. Other than that, I haven't found a use for the bend and go back to my regular dykes when doing commercial and or service work. The angled handles make them take up more room in my tool pouch and feel funny if I put them in my pocket.
All that said, I went ahead and just placed the order.
Knipex Cobra 10"
Knipex Cobra 7"
That's a good start. I shouldn't have talked down about the pliers wrench. Just because I haven't used mine, doesn't mean it's not a useful tool.
Where did you get the pliers rack? Pretty cool
It looks similar to mine. It might be a real pliers rack though. Mine are made from dish drainers that I bough at Walmart and cut the bottoms out of. The regular pliers racks that are sold at Harbor Freight, etc. are too tall for the drawer I keep pliers in. The dish drainer is low enough that I can fit up to Channellock 430's and close the drawer.
JradM
Alberta
I was going to say the same thing!
I too am of the opinion that there are times when a pliers wrench is superior to the correctly-sized combination wrench. Sure, it's much larger, but it can actually squeeze fasteners (pretty hard too) and you can use it with a sort of ratchet action.
Some fasteners - slightly damaged ones for example - really benefit from a "squeeze". Yet another example is on soft fasteners that are really stuck - you can use the squeeze to deform them ever so slightly and break them loose. Brake lines and other hose fittings where you might reach for a flare nut wrench can usually be unscrewed with a pliers wrench too.
The best example of all is when you're not quite sure what size wrench to grab. If you only work out of a shop that's irrelevant, but if you know you need to undo a bolt or two but aren't confident of the sizes - pliers wrench is awesome.
There's lots of tools that claim to replace "a whole set of wrenches", but the pliers wrench is the only one for which that claim has some legitimacy. It doesn't replace an adjustable wrench entirely - but almost. The only thing that sticks out for me is using an adjustable as a backer-wrench.
Comfort grips - I oscillate back and forth depending on the pliers. I generally think of them as the "premium" option, so I understand the allure. However, there are times when I prefer dipped handles. I mention that simply because you may want to consider whether you really want that for all of your pliers (you might anyway, but just think about it first).
Usually I don't like comfort grips on larger-sized pliers. They tend to add quite a bit of bulk to the handle. My hands aren't small, but they aren't gigantic either. A grip that's too big robs power and control. It also makes it more awkward to stick them in your pocket or the slots in a tool bag.
I personally enjoy Channellock's "Code Blue" comfort grips and have quite a few. I've never had any pinching - I strongly suspect that's tool-specific. Give me a pair of 6" needlenoses with Code Blue grips all day long - but dipped-only on the 8" please (as an aside, 6" and 8" needlenose pliers are very different tools in my opinion; 6" for precision and 8" for strength - don't dismiss Channellock in this category, I personally prefer them to Knipex).
JradM
Alberta
Knipex & Channellock are my go to brands. I do have quite a few Craftsman USA made pliers by Western Forge which are very nice as well.
I spy Speed Grips! How do you like them? I swear, I pick them up to hold them every time I'm in the store - but I'm still on the fence whether I should bring them home. Those grips just feel funny to me - I wish they were wide in the opposite plane.
Also, nice collection. (y) We have a surprisingly-similar selection - though not always in the same brands. Where the heck did you find the bent-nose Channellocks?? I haven't seen those before and I NEED them.
Edited to add:
I started googling. Looks like there's an E388 and a 386. The only problem is, they're MORE expensive than the bent-nose options from NWS - at least from what I'm finding in Canada. I have a strong affinity for Channellock, but I don't think that makes sense. I generally think of NWS as a step-up even from Knipex. I might just grab a few new NWS pliers from Lee Valley...
C
CC268
Thanks I went to Home Depot and got the Klein Needle Nose and Diagonal Cutters you recommended. The jaws on the Klein were a lot more precise and looked to have better fitment. I do really like the Channellock feel though! The different colored handles on Klein bugs my OCD haha. I like the blue handles of Channellock but I know that doesn’t mean anything haha.
JradM
Alberta
Angled side cutters are nice. I'd go that route if I were you. Gives you some space for your fingers if you're cutting up next to something.
Channellock 447 would be a good option too.
Odd-job
Wow 100+ posts. Pliers threads are almost as passionate as screwdriver threads...
If you don't want to pay Knipex money, these are a good plier wrench alternative which I didn't see mentioned, for $23 they are a steal:
Edit: The above are rebranded Fujiya pliers (made in Taiwan though), also would check out Tsunoda and Engineers pliers on Amazon. I think they are hidden gems if you are looking for value and appreciate Japanese engineering. Am still a big fan of Knipex cobras and Channellock tongue and grove stuff that being said.
Ton ton
Page County,VA
Actually channellock has those blue handles patented. It does mean something.
Bubba Fett
Eastern NC
Channellock makes great, affordable pliers. Can't go wrong with them. The classic tongue and groove pliers may be "outdated" but there's a reason plumbers still use them. Some Snap-On t-n-g pliers are made by Channellock, if you want to pay 3 times as much for red handles.
Wilde makes Flush-fastener slip joint pliers, which don't have a protruding nut. They don't snag as much, and work great with tool bags/pouches. They make several styles of pliers under their own label, as well as for various companies, including Tekton and Proto.
Klein makes outstanding side cutting (linesman) pliers, diagonal cutters, long nose pliers, and wire strippers. Blue handled pliers have the hardest jaws, followed by red, and then yellow. The Journeyman series pliers are fantastic.
Ideal also has good wire strippers, and other pliers.
^ All of these are USA-made.
Knipex makes excellent pliers wrenches, pump pliers, and diagonal cutters.
For locking pliers, Malco makes the best, Bremen makes some really good ones, and the Irwin Vise-Grips are pretty decent.
For precision pliers, Xcelite used to be THE brand, but I think most of their stuff is made in China now (Thanks Apex!) so they are not as good as they used to be, and a lot of their models seem to be hard to find now. Xuron makes some pretty good ones, as well as Tronex, but they can be pricy (especially Tronex). Tekton has a line of miniature pliers that I may try. There's a whole lot of junk out there, including **** that's made for common brands, like Crasftsman, Husky, Kobalt, etc.
^ Wow! It only took 105 posts for somebody to mention Wilde, who actually produces a better product, although at a slightly higher cost than their largest competitor.
For small stuff, ProAmerica does pretty good, although they're fairly spendy. The larger stuff (groove joints, slip-joints) you're better off going with Wilde.
When I bought my Indestro linemans pliers over 50 years ago, I was informed they were not designed for cutting nails. I generally try to follow that advice, and I'm still using them today. That's what they make bolt cutters for. If you want to cut nails, you use something like this
and keep those nice sharp edges on your expensive pliers. ;)
YMMV
Bubba Fett
Eastern NC
YMMV
Southwire has a few USA-made pliers. I believe Pro-America is the OEM for those. They look a lot alike anyway.
JradM
Alberta
The Wiha bi-cut is cool too. I have a pair - they work well. I bought them mostly for the novelty.
They have a “power” button, which seems like magic. In the “off” position they work like regular side cutters. When you push the button, the leverage ratio changes and the jaws move half as much as they used to relative to the handles.
They seem to cut nails just fine.
KnurledNut
n/a
@sparky 1971 @CC268
My most used 203’s are a pair I customized.
If Klein made this profile, I feel it would move extremely well.
Both pin gripping slots have saved a tremendous amount of headache.
Regarding the 12awg hole, while i rarely use these to strip, I've used them so long I would miss it if it was gone. Angled they will do 14 as well. It gets used as a thread chaser too. And works great pulling small nails.
Sometimes modified tools work the best.
:beer:
Bubba Fett
Eastern NC
@sparky 1971 @CC268
It Klein made this profile, I feel it would move extremely well.
:beer:
Did you cut the teeth in? I wish more companies made needle nose pliers with a section for grabbing round stock, etc. Those look fantastic, BTW.
tyyost
Tunkhannock, PA
Reading through the mixed thoughts on the pliers wrench and I’ll say I‘m a fan. I have two 10”, one in my box and one in my truck kit. They squeeze really well parallel as well as work great as an adjustable wrench. I’ve pressed more than a few things with it to remove a or set a cotter pin, make small bends, etc.
I always take the pliers wrench, my 10” cobras and a set of Channellock 420s when doing a plumbing job. The pliers wrench excels on under sink fittings, and really gives a no mark grip on visible fixtures. Yes, an adjustable wrench would work(always carried a few in my plumbing kit) but the pliers wrench does the same job with a more nimble tool that uses a familiar motion in tight spaces.
I saw two posts I also want to echo, the first was that specialty pliers are worth every penny and make work easier all the way around. I would not fill a drawer with pliers just because you want to fill the drawer, but man, pliers like the Steck 21720 trim clip pliers, hose grip pliers, or lislie exhaust hanger pliers make tough jobs easy. Don’t shy away from picking up pliers for projects, let the work dictate adding to your toolbox. As you jobs go on you add smaller or larger pliers, cutters, wire strippers, etc. I sometimes buy cheaper pliers like Hf to try something out, like diff long handle pliers in straight, 45 and 90 bends to see what I use before I buy better versions. I found little use for the straight and 90 so I ponied up to “good” pair of double joint 45 degree pliers.
sparky 1971
Central Iowa
@sparky 1971 @CC268
:beer:
You use yours for more than I do. I always have them on or near me, but for me job #1 is blowing out the knockout holes in boxes, both metal and plastic. #2 grabbing wires that I can't get my fat fingers on. #3 cutting wire when I drop my dykes and or strippers, if it's romex, the stripping hole makes it a ***** to cut, have to go through it like they are scissors. It's been a long time since I had the pair with the strippers, but I think the skinning hole was more in the center of the cutter. Your pair looks like it's more towards the front, maybe romex would actually fit behind the hole and it could cut with one whack. It's very rare that I use them in the traditional sense of holding and grabbing smaller items. I am going to give you props on the machining though, that's bad assery right there. The profile of the teeth looks similar to my now discontinued Channellock 5410's which I use a lot when doing commercial work.
^ I believe you are correct on those "Southwire" branded pliers I was able to find online. Southwire is strictly a re-brander and re-packager, not a manufacturer:
Southwire / Southwire LLC, One Southwire Dr., Carrollton, GA 30119 / https://www.southwire.com/ / est. 1950 / appears to be more a repackager than a manufacturer /
The "Southwire" branded product might be less money than the ProAmerica branded product. Almost all of ProAmerica's product goes to their private-label accounts, and I don't think they want to compete with Proto and Tekton on prices.
There are a number of Chinese-made knock-offs of ProAmerica's blue-handled (with red stripe) models on the web.
This is only an assumption, but I would think the genuine article would be marked "U.S.A." - at least all of mine are.
Honestly, I wasn't all that impressed by ProAmerica's tongue-and-groove angle-jaw pliers - aka "Channellockcs" - when the Wilde models were obviously more carefully made and had beefier handles. I have fairly monstrous hands and can get pretty much any pair of pliers to do a bit of "flex", including my old 12-inch Indestro tongue-and-groove models.
they really do a nice job on the miniature stuff
some Wilde stuff
