FredWanaker
we have some T8 32 florescents in the garage, and they are only living about 18 - 24 months. Is this normal life expectancy of them these days? Usually GE or Phillips are what we buy.
You're not hearing me. Electronic ballasts come in both instant start and rapid start, sometimes called "program start". The fixtures can usually be ordered with either one. It's common for stores to only stock instant start since they are a few bucks cheaper.Bert, it is an electronic ballast, not a transformer ballast. When I bought these lights they were one size fits all.
Next time you order a fixture, you should just get an LED fixture. I still have plenty of fluorescent fixtures on my property, including some T12 8 footers with 90 CRI 5000k bulbs in them. They've been holding up so far, but they'll definitely get replaced with LED.Ok. Thanks for sharing. Next time I order a fixture I'll be sure to remember that.
I have 4 in my garage that are probably 5 years old. They pretty much stay on all day. I turn them on when I leave in the morning and back off when I get home in the evening. I wonder if turning them on and off all day is what is killing yours ??we have some T8 32 florescents in the garage, and they are only living about 18 - 24 months. Is this normal life expectancy of them these days? Usually GE or Phillips are what we buy.
probably. As I indicated this started about the time my other half started working from home. The same ones in my office last six to ten years.I have 4 in my garage that are probably 5 years old. They pretty much stay on all day. I turn them on when I leave in the morning and back off when I get home in the evening. I wonder if turning them on and off all day is what is killing yours ??
O failures since I started buying led bulbs, but I have upgraded a few as the quality of light has gotten better.
I have not lost a light in the shop since it was built 3 years ago.
I've replaced plenty of drivers in led fixtures already. Had to replace a warehouse of led highbays under warranty, every single one had part of the array go out after 3-4 years.florescents and incandescents - they're just never ending work. And if it's not the tube, it's the ballast.
Go LED, never look back. I have not lost a light in the shop since it was built 3 years ago.
There's nothing magical about led. Still plenty of parts to fail.
See it in almost real time!On a slightly related note:
- longest running continuous lightbulb has been lit since 1901(!)
- bulb life would probably be better if there wasn’t a conspiracy to make them burn out sooner Why we can’t have nice things
I re-wired all my old fluorescent 4 foot fixtures to use ballast bypass LED's too. In my case it was more for how slowly the old fluorescent tubes would take to come up to full brightness in my garage and basement when it was cold in those areas.Converting all my fluorescents, no matter how old, to LED was the best thing I ever did. LED's mostly come with the ability to wire 2 different ways, both eliminating the ballast *throw it out). One is power and neutral at the same end and the other is running the neutral down to the other tombstone. The lamps are clearly marked....
