signcrafter
- Joined
- May 9, 2012
- Messages
- 12,681
I need to try and make one of these tools to remove the ignition lock cylinder in a vehicle. Preferably want to do it tomorrow so don't have time to order one if I can find something I can use to make it. It's just a "J" hook that you use to pull up on a tab. If I can find a wire/rod that is thin enough and put a little bend in it but has to be stiff enough to be able to pull up on that tab. Any ideas? Thanks
www.americankeysupply.com
Ignition Removal Tool - LockTech GM HU100 | American Key Supply
This Ignition Removal Tool was developed to remove the ignition in the “OFF” position in GM vehicles using the newer HU100 keyway that uses a removable tailpiece. It will remove the ignition in the “OFF” position with no damage, no drilling, and do it in less than 60 seconds.
