Hobby_Man22
I bought a miller cst-280 that does both stick and tig. It works when stick welding, but I couldn't get an arc with the tig torch connected. I have a power block with connected with a tweco connector which also connects the argon line. My tungsten is worn down and only like 3" long. Does the steel need to be bright and shiny? I used a roloc sanding disc to grind the rust off and the rust was gone, but it definitely wasn't bright and shiny metal. The stinger made an arc, so i'm not sure if it's the torch or what. The torch is a weldcraft 150 air cooled model.
