Looking for a chisel with a sheath
ive
Canada
Hi all.
looking for a wood chisel with a sheath so it doesn’t cut through my tool belt. Recommendations?
Thank you.
jmj
IL
Hultafors Tools 390273U Chisel HDC 25 https://www.amazon.com/dp/B07Z9WDRJF/?tag=atomicindus08-20
Hultafors 390073 EDC 25 Chisel https://www.amazon.com/dp/B00IZMV4AA/?tag=atomicindus08-20
Or you can go with chisel knives
Morakniv Craftline Carpentry Chisel with Carbon Steel Blade, 3.0-Inch https://www.amazon.com/dp/B00T3ES1SC/?tag=atomicindus08-20
Hultafors 380070U Chisel Knife STK https://www.amazon.com/dp/B07Z9VNGYT/?tag=atomicindus08-20
Bahco BAH2448 Chisel Knife with case https://www.amazon.com/dp/B003ASVQP2/?tag=atomicindus08-20
or pick your own chisel and get a sheath
Occidental Leather 2003 Oxy Tool Shield https://www.amazon.com/dp/B000VXXVGQ/?tag=atomicindus08-20
4 Piece USA Leather Chisel Tip Tool Protectors (1/4" 1/2" 3/4" 1") https://www.amazon.com/dp/B07NJ97Q37/?tag=atomicindus08-20
Taytools 101202 10 Piece Soft Silicone Chisel Edge Guard Set for Chisels 1/8 Inch to 1-1/4 Inches https://www.amazon.com/dp/B07BW5SLZN/?tag=atomicindus08-20
  • Like
Reactions: ive
If your using this on a tool belt, assuming you are doing construction grade work, not cutting dovetails.
If I was trying that, the Hultafors sheath looks good.
I bought a set of the leather chisel top protectors from HJE for travel work, but I don’t think you’d be happy using them for construction work, as putting them back on won’t be a simple one handed operation, just dropping it in the sheath.
  • Like
Reactions: ive
I
ive
Canada
Thanks for all this. I will look at it all. Much appreciated
I
ive
Canada
Yes. Hultafors looks good.
KnurledNut
n/a
Fastcap has a set of chisels where the handle folds over the blade butterfly style that seem to be designed for tool belt use. I go to have any but have looked at them several times at the fastcap site.
Stanley also sells similar.
OL Oxyshield, Mora and Hultafors are all good, but can be bulky. I have experience with them all.
Terra Nova
Just picked up a Moraniv Chisel Knife. Haven’t used it yet but seems pretty handy. For under $20 can’t go too wrong.
garfieldzzz
BY
I personally can recommend the Hultafors HDC chissel, like it so far, also dulls not to fast.
Iridium rand
This stanley one (fmht9-16067) has done very well by me over the years, dewalt makes a very similar one that could be a rebrand, very nice and durable sheath too
