I'm still working through mine... Fed is done except for double checking - then the State is next.Just finished with our tax account. Got our duty to the treasury done and started our plans for the 2022 return.
Everytime I think about mine it makes me want to pull one out of storage and strap it to the trailer deck when I'm hauling a load. I saw a picture of a tractor trailer driver who does this. It's a fun idea and kids get a kick out of it.Every time someone posts a Tonka resto it makes me wish I hadn't given all of mine to my younger cousin.
Tommy
Buttoned up the front end "rehab" (definitely not restoration, as evidenced by the photos) on the '72 Chevy. Just bleeding brakes and power steering, then waiting for winter to be cleaned from the roads before the test drive. Probably another month, at least.
How well does your HVLP do going through that little yellow coil hose?
Be glad they're fronts. I bought 20 inch rears for my Toro zero turn yesterday. I was way off on my guess at the cost. With tax and mounting it cost me over $180! I'm glad the first set made it over 10 years. I can buy some speed rated car radials for that.New front tires for the mower. One down - one to go.
Saw this in Austin a few years ago.Everytime I think about mine it makes me want to pull one out of storage and strap it to the trailer deck when I'm hauling a load. I saw a picture of a tractor trailer driver who does this. It's a fun idea and kids get a kick out of it.
I have not used it yet to shoot anything. I’m using the yellow coil to jump off the wall connector to the regulator/dryer. I’ll likely use the orange hose on the bench for the hvlp off the connector at the end of the bench. I have yet another smaller regulator that sits directly on my hvlp gun to knock the pressure even lower. i do not believe the coil will be an issue.How well does your HVLP do going through that little yellow coil hose?
Doug, the issue isn't knocking the pressure down, it's knocking the volume down that hurts. Think of it like filling a pool with a 1/4-inch hose and low pressure. A tiny dribble of water will take forever to fill the pool. If you feed the water through a 1/2-inch hose at the same low pressure, the pool will fill much faster. If you have some way to connect your High Volume Low Pressure gun to the compressor with a bigger (at least 3/8") air line and high flow fittings (Milton V-Style) the gun will perform much better. If you use the smaller hose and small fittings, the gun will spray poorly until you crank the pressure way up. Here's a chart from Milton Industries that shows the different flow ratings. The typical A-Style fitting flows 34 SCFM compared to the V-Style fitting's 74 SCFM.I have yet another smaller regulator that sits directly on my hvlp gun to knock the pressure even lower. i do not believe the coil will be an issue.
Thanks for this. I did not realize the negative impact that coil will produce. I will look into a 1/2” short jumper h off the wall to the regulator. I had the coil laying in a cabinet and wanted to use it.Doug, the issue isn't knocking the pressure down, it's knocking the volume down that hurts. Think of it like filling a pool with a 1/4-inch hose and low pressure. A tiny dribble of water will take forever to fill the pool. If you feed the water through a 1/2-inch hose at the same low pressure, the pool will fill much faster. If you have some way to connect your High Volume Low Pressure gun to the compressor with a bigger (at least 3/8") air line and high flow fittings (Milton V-Style) the gun will perform much better. If you use the smaller hose and small fittings, the gun will spray poorly until you crank the pressure way up. Here's a chart from Milton Industries that shows the different flow ratings. The typical A-Style fitting flows 34 SCFM compared to the V-Style fitting's 74 SCFM.
Kay you turn a lot of pens, what do you do with all of them?Fixed a few things. Sharpened the pen blank end mill. Reamed a batch of pen blanks. Turned a bunch of pens. Sanded a pair of special dice.
Sell them. They have pretty shiny ends n middles, that attract the eye. Drawing the customer to check out the other **** at the booth. I enjoy making things, and luckily enough what I sell, mostly, supports my idiocy. I'll never get rich. But then the idea is to have fun and not lose my shirt.Kay you turn a lot of pens, what do you do with all of them?
Nice!Sell them. They have pretty shiny ends n middles, that attract the eye. Drawing the customer to check out the other **** at the booth. I enjoy making things, and luckily enough what I sell, mostly, supports my idiocy. I'll never get rich. But then the idea is to have fun and not lose my shirt.
Bob did a lot better of job of explaining my concernThanks for this. I did not realize the negative impact that coil will produce. I will look into a 1/2” short jumper h off the wall to the regulator. I had the coil laying in a cabinet and wanted to use it.
