Ratchet lubricant?
Rickkyyr8
What lubricant do you guys recommend to put in a ratchet? Got a bunch of older ratchets passed down to me that I’m cleaning up and want to get them back fully functioning the right way
Steve W.
Southwest oHIo
Great timing for this thread! (y)
I just received a rebuild kit for an old Snappy 730, was wondering what would work.
lardy1
I've run the gamut on lube options and have decided 3 in 1 oil works best overall. SuperLube screws up some of my fine tooth ratchets and the Red Lube Of Love expiriment wasn't all that impresssive to me. In reality, I don't think there is one best lube for all the different ratchet mechanisms out there. I just find the light oil works at least adequate on everything.
isb cornbinder
I do not recommend using any lube in a ratchet. I have ratchets over 75 years old. A ratchet system does not move quickly, so a build up of heat that might cause galling is not possible. I bought a torque-wrench with a ratchet that would skip without warning. I took it to MOTION for calibration and a fix. It was suggested that I do not replace the lube. What was in the ratchet had dried and was restricting the ratchet pawl from engaging.
If you insist.
MarkH
Kansas
No one answer
Low tooth count Super Lube
Mid tooth count Lucas Assembly Lube
High tooth count Marvel Air tool oil
Real old and very low tooth count. Lightweight grease
My frustration with new ratchets is almost everything comes dry. Only the real high price automotive and some industrial ones have had lube in them when we got them.
Old Donn
Another vote for Permatex RLL. I have used STP in the past, but use with caution. A little goes a long way.
egdede
'red lube of love' was coined by a user 'Merkava' (I think) who hasn't been around for a while. I have my suspicions about Merkava having assumed a new identity...But they are just suspicions.
gatewaysysop
Arizona
I use Super Lube as shown above, so far in almost everything I have needed to refresh. As has been mentioned, for higher tooth count ratchets you really, really need to be sparing with the application. Snap On uses Super Lube and I think Matco kits used to come with some version of Marvel oil.
In a pinch I have used 3-in-1 without ill effects. If I had some Marvel on hand, I'd probably give that a try in higher tooth count, but if not, Super Lube works as long as you're careful.
anndel
Hawaii, USA
I have a 1980's Snap-on flex bent handle ratchet and couldn't figure a way to get inside to lube it. A SO driver once told me just soak it overnight in ATF. My current drive took it apart in 30 seconds, cleaned and lubed it using what looks like Super Lube.
cjarvis
Super lube for most of mine, but sometimes, if they're especially fine-toothed and don't seem to like the super lube, I'll give them a light coating of 85W90.
sk farmer
nd
rll goes in most things. especially the proto big dawg rats.
the lube specified for the danaher style ratchets such gearwrench , matco, armstrong with 60-88 clicks is marvel mystery oil. i have tried other things but that seems to be best for them
BigLeagueSmoes
Central IL
I have used...
Super Lube synthetic grease for course ratchets
Super Lube synthetic spray for fine tooth ratchets
ATF and Mobil 1 motor oil for fine tooth ratchets and ratcheting wrenches
In my unprofessional opinion, honestly there are so many good options that will provide rust/corrosion resistance which is what you're looking for. Yes lubrication is helpful too but in reality the amount of use it would take to wear a ratchet out just from the friction during regular use is seemingly unattainable, possibly decades and hundreds of thousands cycles. The difference in lubricity properties between something like super lube vs red lube.. so marginally small. Much more likely to rust or break before wearing out. As long as your lube isn't too thick to gum up the moving parts, you should be good :thumbup:
RickyPetite
Buck's County, PA
Superlube or Red Lube of love - coarse ratchets (note: Red Lube gets quite thick if you live in a very cold climate)
Starrett Tool and Instrument Oil - fine ratchets
Steve_P
I'm a superlube fan in most ratchets- SK round heads, old school Proto, Blackhawk, Williams..... But it does just not work in the new 90T floating pawl ratchet like the Tekton and the SK. It's too sticky and the pawl sticks to the main ring gear. So the answer is that it depends on the ratchet if you want to use Superlube.
WWheeler
Middleofnowhere USA
Which SuperLube? They manufacture at least a dozen different greases and oils.
The Super Lube 21030 synthetic grease pictured in the third post on this thread is what I've always used in every ratchet old and new no matter the thread count. Not really sure why some think it's not that great for fine tooth rathets. It works flawlessly in all of mine lasting a looong time with the least backdrag of any other I've tried, including RLL. It's the exact same lube that comes in a little packet with Snap-On's dual 80 rebuild kits. The same lube Snap-On supplies their dealers with for rebuilding all of their ratchets. Don't pack a ratchet with too much. A tiny bit goes a long way.
EDIT: Outahere a few posts below this noticed the tube pictured in the 3rd post is actually a heavier grade of Superlube (NLGI2) whereas the little packets in the snappy kits are NLGI 00.
Outahere
Idaho
The Super Lube 21030 synthetic grease pictured in the third post on this thread is what I've always used in every ratchet old and new no matter the thread count.....It's the exact same lube that comes in a little packet with Snap-On's dual 80 rebuild kits.
I checked the SuperLube part number on the little tube in my dual80 kit, and it reads 82345/00. The /00 suffix indicates that the lube is a NLGI 00 grade. The larger tube of 21030 is a thicker grease, a NLGI 2 grade.
WWheeler
Middleofnowhere USA
That's a good catch. I checked the back of the tube in mine and you're correct. Damn fine print! I need to add an edit to my post above to reflect that. I assumed the tube of superlube grease with PTFE pictured was the same stuff. I just did a cursory search and I'm not even seeing where that NLGI 00 is available in a small tube or even in a pack of 10 or 20 or so of those little packets. I did see at the superlube site you can order a 14oz tub or cartridge for $20 + shipping which is another $20 to where I live anywho.
Outahere
Idaho
As you say, no availability in small quantities, which is a shame. SuperLube NLGI OO grease in the small 1cc tubes is only available in a minimum quantity of 5000, for $3000 !
Handyandy23
Ontario, Canada
SuperLube worked well in my 72 tooth ratchets, but totally buggered up my 90 tooth ratchets. It was too thick and caused them to skip and self reverse like crazy. Cleaned it all out and used RLL with success. I've also put 3-in-1 in my 120XP ratchet because it's even thinner.
Basically a thicker lube like SuperLube will give you a smoother ratchet, as long as the teeth aren't too fine. But first and foremost you need to make sure what you're using isn't too thick. RLL seems like a reasonable middle ground that works well in "most" ratchets.
Steve W.
Southwest oHIo
Just for good measure to accent the point I made in my last post, I dug out one of the rebuild kits I've got so you can see for yourself what lube Snap-On uses in their dual 80 ratchets.
I finally got around to opening up my rebuild kit. That little tube of lube that WWheeler shows was included. (y)
Now I need to figure out what is not working properly with that ratchet. The face that holds everything together does not seem to fit correctly, and it I try tightening the screws, it just binds up the mechanism. Seems like the drive (the 3/8" drive and ratchet gear) is too thick for the available space.
rick carpenter
Huntsville, East Texas
All four of my Gearwrench 90Ts work very well with 3-in-1.
Chumly
Alpine, CA
Looking through all this I feel like Jeff Goldblum and nodding, "There ya go, use lube."
Bringing back to life, to me, would be opening them up and restoring whatever action they previously had, if you can. Action could be the guts and gears resting in rust remover over night as lube ain't helping with a slight build up in a cog holding things up. If you can really take it apart, it's serviceable. I don't see harm, if they've really sat around a while, to rest the head in rust remover (pick one) over night then soak it in 3-in-1 marvel just to get it back to life.
Tools at rest, stay in rust. Tools in use, stay in lube. There's got to be a known law about this by now. Take that Newton!
I have rusty industrial finish tools because I don't use them anymore. Tools at rest...
