ZRX61
Tool round up & put away. A screwdriver that has been missing since we had contractors in still hasn't turned up. The real pisser is that's a German CK which are hard to get in the US.
I can imagine initially thinking that trapping a problem skunk would be a good idea until I actually ended up with a skunk in a trap. At that point, I would question my logic and wonder WTH do I do now?
Obviously you've already thought through this (?) so what do you do once you catch one?
I've had a similar stand for about 45 years except my base is an old brake drum from the Chevy van I had at the time.
Rage fixed something that’s been ******* me off for decades. When I change the oil on the tractor the drain plug just drains all over. Couple of fittings and 2 feet of hose.
Anyone else rage fix stuff?
Over twenty years ago I mounted my Harbor Freight grinder in the same way. I used a 15" steel car rim and a chain link fence post. The post was a great fit in the rim's center hole. The post touches the ground. I welded the post to the rim and it has worked great without extra weight. All I have to do to move it is lean and roll. I suggest you try it as is before adding the concrete. Of course I don't work mine any harder that wire brushing bolt threads and sharpening mower blades.Refreshed my bench grinder.
I was given this bench grinder back in 2000.
I had some free time yesterday, so I decided to give it a good cleaning and paint it.
I also installed a wire-wheel on one end.
The stand is made up of an old car wheel, a section of pipe and flat plate. I plan to fill the upper half of the wheel with concrete to make it a bit more stable.
F18's don't mess around..lol We had a few fly over our area twice. Only time I ever heard a sonic boom in my life.About **** my damn drawers. Was bending down to get something from under my bench & we had the biggest sonic boom that I've heard since we had Shuttles land at EAFB. Rattled the entire house, actually heard wrenches clatter together in the toolbox across the garage, set the dog barking & knocked my ISP off line for a while. Heard a bunch of car alarms going off at the college.
I'm well impressed
I can't even imagine that. The closest thing to that is when 9-11 happened, there were fighter jets flying for a good 24 hours. No sonic booms, but a constant sound of fighter jets, it was crazy. I live close to an international airport, I assume that's why they were in the area so long.I remember visiting family in E.Germany in my youth (early to mid-80's) and hearing the sonic boom over my uncle's house as the MIGs patrolled the Iron Curtain.
Another (proactive) solution I've heard of is a very light coat of RTV where the wheel contacts the drum/rotor.Hey, Ben, the next time you have to remove a wheel you think might be stuck, first crack the lug nuts loose, then move the car a couple feet and slam on the brakes. I've only one time found that it didn't work and had to resort to a big hammer.
I went the same route with an Olds Intrigue we had. Replaced 3 drivers side fenders (1 for wife and each kid) and both drivers side doors. Sourced them thru car.part.com and kept the car reasonably presentable with matching body panels.Finished replacing the door and fender on our Volvo with color-matched used parts. It was backed-into in a parking lot by someone last month
Replacing the parts was cheaper (parts only) than going the route of deductible and insurance hassle.
I used rivnuts in place of all the rivets I drilled out when I swapped the original door components over to the replacment door.
I'm trying to reduce the number of projects I have going around here, but it doesn't help when others make projects for me![]()
Would look better with the feet facing inwardsFarted around with a couple projects for my wife. She’s into McKenzie, Childs treatments with a twist. Wanted a “foot“stool. Heres first concept. Ive discovered I don't have an ankle fetish. Will be foam and fabric covered.
Need advice on a base for a tractor seat stool. Ive got seats and a nice big link chain from a honey wagin for the post. Need something novel for the roll about base. Regular old car wheel is out. Might try a jack stand. Ideas?
There is a story here...Washed gasoline off my face.
