Hi, I have been reading a bunch of posts on the wonderful Garage Journal site regarding bowing walls and my situation seems different than most (it always is).
I have a detached 1930's garage that I have removed the roof off of because of 6 layers of shingling, rotted roof boards and yes the bowing walls. the roof was made up of 2x3 joists on the 30", and a 1x6 ridge board made up of 3 sections along with 4 collar ties. The garage is 12x20.
The front of the garage is solid and straight there is no bow in the walls. On the back of the garage the left wall bows out about 1-1.5 inches and the right wall bows in 1-1.5 inches. Most of the scenarios that I see feature both walls bowing out.
As you can imagine going from front to back the bow gets larger until it hits the 1.5 at the back.
As i said the roof is off and the walls are tied together with 4 1/8 steel cables and turnbuckles. The studs on the back wall are also straight
What would be the best way of straighten out the two side walls?
After I get the walls straightened as stated in another thread I want to increase the height of the walls by 3' by sistering studs onto existing and then put on new roof.
I have attached some pics
Thanks
Thanks
