1100 ft lbs - DIY Torque Wrench Extension
b-dog
Lakewood, CO
I thought some of you might enjoy this...
I recently had a nut that needed to be torque'd to 1100 ftlbs and my biggest torque wrench only goes up to 600. My multiplier only goes to 1000 and, for no particular reason, I don't like using that thing anyway. I don't have nor did I want to rent one of those structural electric wrenches and I'm not sure I would have been able to brace it against anything.
Here was my solution, a 4'-6" extension. Multiply the 450 ftlbs torque setting on the 3'-0" torque wrench by 2.5x and voila! At 7 1/2 feet long, this mess is a bit unwieldy but it worked.
BukitCase
Oregon
Torque spec on the biggest hydraulic cylinder(the piston bolt) on my Case backhoe is 1000-1200 ft lbs... Steve
CS454
Wow! what the heck kind of nut needs 1100 ft lbs?
(I'm a bit of an amatueur wrencher and have gotten by with a 150 ft.lb torque wrench lol)
We have axle nuts that require 1200 lb ft on our equipment. Double barrelled 3/4" torque wrench does them up nicely.
couch67
Ontario Canada
Yeah as a backyard mechanic I think the most I've seen is the Honda crank pulley bolt - torque to ** foot lbs (forget target, but around 100), then tighten another 60 deg. Fine going on, not so much when coming off.
BukitCase
Oregon
There are entire different worlds out there with vastly different scale that people who haven't seen them up close, have no concept of - my last 34 years before retirement I worked in instrumentation in rare metals plants - we had hydraulic forge presses that used cylinders with 3 FOOT diameter rods - each 4 foot long stroke took 250 GALLONS of hydraulic fluid plus another 450 gallons for the two slightly smaller cylinders flanking the center one - there were 3 separate pumps, each with a 300 horsepower motor, and the press could re-shape a 20 foot long, up to 40" diameter, typically 20-25 ton ingot of Zirconium into a 6" thick slab, in 3 or 4 passes. the jaws of the press were a little over 8 feet long and 2 feet wide. You could feel the heat coming off those ingots from over 100 feet away.
There's a machinist on another board who works in mining; he routinely line bores bearings on big mine shovels, the pivot pins are 16" ID, IIRC - the typical dump truck you see on the road holds 12 cubic yards - by comparison, the bigger mine "shovels" (excavators are a smaller version) - the mine shovels' buckets hold 65-70 cubic yards, and it takes 3 or 4 buckets full to load ONE truck.
It's a little bit like thinking you know how big a bengal tiger is, BEFORE you actually see one in person... Steve
b-dog
Lakewood, CO
haha I was torquing pinion nuts on a military truck axle.
I work for a crane company and we've used up to 1 1/2" structural nuts which require up to 3,500 ftlbs. Totally different application/tools/methods that wouldn't work for what I needed.
What is this?!
Wpavlis
I did a similar thing for the u bolts on my 68 chevy c10. I couldn't afford to purchase a 3/4 torque wrench for 4 nuts. welded up something similar, but it was only 24" long.
jubilee
Colorado
There are readily available formulas for computing torque by adding extensions (cheaters) to torque wrenches.
I’ve been using them for years, but for field work I use a beam torque wrench, non flexible cheater, and add 15-20%... gets very close to doing all the math.
b-dog
Lakewood, CO
Update, I'm a hack and a fraud. It goes to 1000 Lb Ft and 1500nm. The axle torque spec I quoted above is in nm, as per my service literature. :censored:
Anyways, people like pics right?
That's awesome, I've never seen or heard of such a thing.
