I started my basement woodshop with a setup similar to the Jet DC-1200, but determined a 2HP blower would not meet my requirements, so I upgraded to the 3HP version by Bernardo. The only component of the system I used was the blower and built this around the Oneida 5-inch Steel Super Dust Deputy, a pair of Wynn Environmental 35B222NANO filters with catch pans for clean out, and a 35-gallon plastic trash can.
The trash can collapsed while I was in the middle of a large project and I didn't realize it until the filters filled with dust and chips. I had to disassemble the system to clean out everything, including the impeller blades in the blower. If the seal between the trash can and lid isn't completely sealed, a lot of what is sucked up by the blower will pass through to the filters. As soon as the can buckled, the seal between the rim and lid was broken. I used some plywood offcuts to build an internal brace for the trash can and haven't had a problem with it since.
The blower and cyclone need to be matched, as well as the ducting size and routing. The Oneida Super Dust Deputy XL is made for 3-5HP blowers and will likely not be a good match for your blower. The 5-inch Steel Super Dust Deputy is made for 0.5 to 3HP blowers and is better suited for your 2HP Jet blower.
I recommend you wade through the Bill Pentz website before you go too far down the DC rabbit hole. The information is overwhelming, but Bill lays out everything you need to make an informed decision on your DC design. I made some mistakes in my DC system. Although I used 120mm (5-inch) steel ducting for my system, I foolishly put two 90-degree bends immediately at the input to the cyclone, which I later learned is a big no-no because this reduced the airflow considerably. The system still works well, but I know it can be better with more attention to proper design practices.
When I fix my errors, I will also change the 5-inch cyclone with the 6-inch Oneida Super Dust Deputy XL. My 3HP blower is at the transition point between the two cyclones, and I want the larger cyclone in case I find a good deal on a 5HP blower. The 6-inch cyclone is taller than the 5-inch cyclone and since I can't raise the blower, I had to reduce the size of the collection can. I built a plywood box that will fit under the new cyclone and still have about the same 35-gallon capacity.
