SqD Euro pushbuttons,any info on them?
toplessHO
central florida
How in the blank do you get them apart?
these came assembled in a box
Hole in cabinet is punched but they need to be taken apart to install.
The chrome bezel is what comes off the body to insert thru hole in outside of cabinet.
SchneiderElectric is the parent company of SqD,these are made in France
This is part of a NEMA 4X cabinet,all is gasketed but wonder if the pushbuttons need a membrane cover
for outside exposure.Again I found nothing on this style of PB
Norcal
Look at the spot on that stop button in the top of the photo, there is a spot that a straight blade screwdriver should release when pulled back, some brands of 22 MM PB are easier then others, the Europeans seem to be able to eff up a *********.
T
toplessHO
central florida
Got it,thanks.
Any ideas on if this needs a membrane cover to be raintite?
Norcal
Got it,thanks.
Check the SQ D catalog, to see what rating they are would hope they are NEMA 4 or 4X, but might have a IP rating instead.
T
toplessHO
central florida
in checking the boots for sale it says they are IP66 rated
I cant find anything on the pushbuttons so may just get a couple of boots to assure they are raintite.
T
toplessHO
central florida
Loosen the center screw and twist the back off the body
it doesnt work like that.
Norcal pointed me in the right direction
the hook shaped lever pulls out and releases the retainer for body of the pushbutton
T
toplessHO
central florida
just got word from the supplier that the buttons indeed are outdoor rated.
I had already ordered the boots ,which will be here in a week.
