There was a recent Knipex VDE promo set locally of the following for 69eur, which I missed.
So I decided to up my game; only the needle nose is the same with the above set.
74 06 200 Knipex High leverage cut 200mm, this theoretically can chew through steel nails. The set above has the standard 70 06 160mm cutter.
02 06 200 Knipex High Leverage combination pliers, this can also chew through steel wire. The set has a standard 03 06 180mm combi pliers.
26 16 200 Needle nose pliers 200mm.
A thin adjustable wrench from Irega, Made in Spain. Wanted a similar Bahco one but the shop didn't have it, Irega is also a good brand. Opens to 40mm
Some extra bits. Liquid teflon sealant, some very comfortable eye protection and 2 sets of work gloves (I need Medium sized gloves
