Thank you so much for the link. It’s hard searching without a computer. I have a small phone. Now I will find someone to print it for me. I can’t wait to review when I’m off work. Maybe I can figure something out. Lol I really appreciate the help!
Sometimes you just need to search around the internet to find what you need. Here you go, this is your DP manual.
Based on the badge its more likely your drill press is mid 1950s. Probably 54-56.Thank you so much for the link. It’s hard searching without a computer. I have a small phone. Now I will find someone to print it for me. I can’t wait to review when I’m off work. Maybe I can figure something out. Lol I really appreciate the help!
I stumbled across this group while looking for parts and advice. I am about to attempt to rebuild and refurbish my late father's Craftsman press. I cant even fathom how many hours I spent on that press as a kid with a sanding drum, just shaping wood. I am curious what the factory color was. It is currently a dirty rust color, and has the original motor. So, before I start sandblasting this beast, is there any advice that any of you wish someone had told you before you started?
Btw, I was 11B3J until 2006, then I was a straight 11B30
Here are a few pics, I will try to get some better ones tomorrow. The Model appears to say 115 6962
Also, do NOT use anything abrasive on the aluminum band, the engine turned finish is very easy to remove accidentally.The date code is stamped on the bottom of the motor plate. Looks like 48, for 1948, which I'd say is correct based on the features of your drill press and the badge.
That paint will probably clean up okay with some wd40 and a scotch brite. It's the original blue/gray color.
1. Ted, see the links in post #43 above. Also check out this link:
There is a tab for publications reprints.
2. FrankLee is a member here on the forum and the creator of the Classic Craftsman Drill Press Thread. It was the go-to thread PTU (Prior to update). The update broke all the links and the thread lost a ton of information. Regardless, Frank is a personal friend and he responds to private messages. So feel free to reach out to him through the message feature of the forum.
3. Can you locate a model number on that drill press? Also we often date drill presses based on information found on the motor. If its the original motor then is may also have information to assist you. Often a stamped # on the data tag will be a date code. You have a nicer drill press there.
Hi Ted, welcome to GJ. As for that Walker Turner made Craftsman DP, they are uncommon for sure, but not rare. In the last 16 months I have obtained 3 in the SoCal area -reconditioning one and reselling it, parting out two not worthy.
I was not able to find an exploded view or manual for this particular DP but that doesn't mean one is not out there.
Obviously what makes them a unique design is the inverted spindle pulley, depending on the amount of rust or wear, removing this spindle pulley can be a straightforward process, or a white-knuckle, lots of cursing experience such as the last one I dissembled. Replacement parts for them are not easy to find. I sold a spindle pulley from one of the machines I parted out and the buyer sent me an emotional email, telling me he had been looking for over 5 years for a WT inverted spindle pulley to resurrect a machine that had sentimental value for him.
Yours seems to be complete, and nice addition with the Delta retirement light.
There's a few different versions of this machine, all based off the WT D-700.
Yours is unique in that I've never seen a floor model. Nothing Sears did or procured back in the day surprises me anymore. Here's a bench model I picked up a couple years ago (Wearing a horrible color choice which will be corrected one of these days). Worst design for a drill press I've ever encountered based on the spindle pulley Hoorn mentioned.
It's interesting in that for, what we assume, is a relatively short run, there are at least two different head castings out there with the Craftsman brand. One runs the word Craftsman horizontally, the other at an angle. There's other minor differences as well.
Not near as good looking as yours. Thank you for posting this.That's a cool machine you've got there Ted.
I picked up this DP today 2 cities over for $100.
Beyond the DP, which was in great condition, was this very uncommon 1955 Craftsman Repulsion Induction motor. I have never run across "Sears vendor 551." before and may never again. This motor was made by Leland Electric Co, in 1955 a division of American Machine and Foundry. Believe it or not, this motor is wearing its original paint! It almost looks NOS.
Here is the commutator cover side, where directional travel can be adjusted by rotating the brush ring.
And the brushes and commutator. Note the darker ring of cast iron that was under the cover. I did a double take when I saw that, but the paint is indeed original and visible behind the badge, Further, the manner of the paint under the motor and the precise Craftsman blue gray that matches the drill press dead on confirms this. Even the inside of this motor is super clean and in great condition.
It sounds amazing and runs utterly smooth. This is unlike any Craftsman bullet motor of the era with its thick steel band and welded steel base. It more closely resembles a Delta motor of the era
Here it is in the 1955 Craftsman catalog. Part of the reason these motors are so uncommon was the price tag. $41.95 in 1955 is $458 today. The recommended 1/2 HP Capacitor motor for most machines requiring 1750 RPMs was $26.50, or $283 today. Since it was almost double in price and marketed for heavy duty farm or industry work, these don't pop up much and definitely not in this condition!
What!?!? Why would that get locked?With the original "Craftsman drill press" thread locked, we can go ahead and make this the de facto Craftsman drill press thread moving forward.
I am absoluley at a loss right now....this haul was yesterday and that amazing RI motor from todayWith the original "Craftsman drill press" thread locked, we can go ahead and make this the de facto Craftsman drill press thread moving forward. I just picked up a Craftsman 100 benchtop for $100. There was only one picture of it in the OfferUp ad.
All you savvy Craftsman drill press guys probably noticed like I did that the motor pulley was inverted which told me there was most likely an MSA pulley hiding in there. I reached out to the seller and sure enough it had a gorgeous multi-speed attachment. Nothing unusual about this one, Hoover bearings.
This was one of those OfferUp deals that you only dream of. While on the way the seller reached out to me and mentioned that the DP belonged to his recently deceased father who was a machinist. He said he has boxes of machinist tools and other "junk" and would I like to take those as well, included with the $100. I replied that I would have no problem taking those boxes.
When the dust settled and I got home, here is a partial list of some of the items in the boxes:
2 Cardinal speed vise 3 & 4"
1 Brown & Sharpe 6" milling vise
15 Huot drill indexes filled
9 Union drill indexes filled
10 National reamers indexed filled
Numerous Starrett gauges
One bazillion drill bits
Numerous all US made taps and dies
And for the topper:
Seven Albrecht chucks, one Starrett chuck and a cool T handle chuck. And I have not gone through all the boxes yet, and he's reached out to me again and said he has several more and would I like them also?
Albrecht chucks are the real deal and probably the best made in the entire world. Keyless, they turn like absolute butter and they have the tightest tolerances possible. New Albrecht's start at around a grand or more, micro chucks around $500. Was pretty happy with my $100 purchase.
I understand that his schedule allows him to drop things at a moment’s notice to go grab machines but I think he is perhaps rivaled in location only by Chicago or perhaps Pennsylvania or some of the other old states with tons of machine goodie’s! At any rate he finds the best stuff!Smokes, Hoorn lives in the land of machines. His access is unprecedented. I would not want to live in CA for other reasons but the amount of vintage Craftsman and Delta tools he finds is just amazing and you are probably correct about the tatoo.
I am looking forward to it! I don’t have any of those accessories but if I do find one soon would help contribute. Thanks for taking this on!Well brothers and sisters, I am hoping to upload video #2 tonight. It is a quick evaluation of the craftsman drill press and a brief overview of web based resources such as this thread, GJ and vintage machinery. I have all the raw foot shot for the disassembly and assembly videos but those will take longer to voiceover, edit, and break into a series of videos. So things are moving along. I may be reaching out to a few of yall (Hoorn) for some home made videos of accessories and other things I do not have on hand here in Dixie.
Also Jziggy is local and stopped by a week ago to share with his newly acquired (near mint) very rare Craftsman slow speed converter for band saws to play with so I will be doing a video on that as well as his slow speed pulley system for the Craftsman Drill Press in the near future.
Accessories that I do not own and I will be looking to highlight will be:
Multi-Speed Attachment
Production Table
Vari-Slow Speed Control
Varible speed 1/2 HP motor
Tilting tables
Mortising kit
Table lift system
and any other accessories sold by Craftsman during this era.
So feel free to reach out to me is you have some of this stuff and are willing to knock out some video with your cell phone and send it to me for use. Before anyone asks, I am a poor government employee so no, you will not be paid for the content and I need 1000 subscribers before I could ever monetize my youtube channel. Besides, I am not do this for money, the entire purpose of my channel is to share the information to anyone who finds it useful.
