BRENT in 10-uh-C
I have an engine assembly room at work that we have damaged some VCT tiles in by dropping heavy metal objects (engine parts) which has chipped the tiles. I realistically do not have the time to remove tiles and start over, but we are removing most of the cabinets and benches where we can strip the wax and reapply the floor wax as routine maintenance. What I am wanting to do as a 'bandaid' is to fill the chip damage with some type of epoxy that will level the floor somewhat so that dirt won't hide in the crevices and mopping the floor during clean-up will be easier. . I also need to use something that the floor wax will adhere to Is there some type of 2-part epoxy that I can use just to semi-level the surface until I remove the flooring and start over?? Maybe a clear JB Weld epoxy? Something else??
Below are some pix that shows the damage. Yes I realize this is severe, but it is a work area that has employees using it everyday, and I just need to fill the "holes" so dirt & grime does not collect there.
