New Tire Machine advice
Sammajor2000
I'm setting up a mobile tire shop and seeking advice for a reasonable Tire machine and wheel balancer. I'm looking for something afoordable but with a good quality as possible regarding price.
Corghi?
Ranger?
CEMB?
Any suggestions are so welcomed
39CAMC
St. Louis, MO
Center post mount stuff is all around the same price. I am a Hunter fan boi with Corghi a close second, but a lot of what you need will be determined by space.
My Hunter TC39 leverless is great in the shop, but weighs 1000# plus and has a huge foot print My trackside machine in the trailer is a TC3300 as it is lighter and smaller footprint.
DaveW
Sammajor2000
DaveW
actually i'm looking for rim clamp
39CAMC
St. Louis, MO
An opinion you didn't ask for, feel free to ignore: I know that rim clamps *can* be used without damaging the inside of wheels, but judging by the number of wheels I see with the tell tale divot dots or scratches on the inside of the rim barrel, or chunks out of the inside bead, not many techs take the time to actually use them in a damage free manner. Like less than 10%
DaveW
Xcursion88
DaveW
Most...not all...but most custoners have so much road grime built up on the inside of their rims they can't see the 9 dots per spot nor do they care.
If someone does care it's pretty evident by either a newer car and or aftermarket wheels to which gets clamped on the outer wheel edge with no blemishes left behind
39CAMC
St. Louis, MO
Each shop to their own. I tend to not try to destroy things just because the customer can't see them when done....
And it's a giant PITA to clamp on the wheel outer edge, you have to break the bead first and then can't air up with it clamped, it is no wonder most techs wouldn't do that very regularly.
But a center post machine fixes both problems
DaveW
Xcursion88
DaveW
So you accuse of destroying things to which nothing could further from the truth but then conplain of the pita to axtually do it the right way bu clamping on the outside?
I live in the rust belt and trust me when I tell you steel wheels get pretty bad all on their own hiding underneath wheel covers.
At the very least 75 percent of the wheels we get have previously been clamped by someone else on the inside with the subtle teeth marks on the inner part. Virtually all steel wheels and most definitely aluminum wheels are damn near 75 percent. Especially on steel wheels. Clamping in that same spot is negligible and I don't know about you but we've never once got a complaint about teeth marks from a previous garage or us especially on wheels you can't see underneath plastic wheel covers.
We don't care nor complain about the extra step involved in clamping on the outside to do the job right.
What we do hear complaints about repeatedly is other garages (even new car stores) putting clamp on wheel weights around the rim edge of their nice looking aluminum wheels. Something we never ever do. Ever!
I'm sure you know exactly what I speak of with that. Places trying to save a buck reusing clamp on weights no matter the wheel finish. That's completely unacceptable
