Maninthesea
I recently purchased these two cylinders at a surplus auction $30 so I could not pass up. I have googled the part number (109384) and look for pictures to see examples of how the ball Is held and to get a good idea what the intended use was for so I can figure out how to repurpose them. I would assume the two fiber bushing looking things clamp inside of a sleeve that has adjustable compression And a grease zirc In the middle of the grease the ball to reduce friction/wear. These would be the cyl mount. The end of the rod on the side of the brass ball is threaded externally so I assume it is what is pushed. Other end is smooth.
thanks in advance
thanks in advance
