Save this lathe from the scrap pile
Packard V8
Spokane, WA
That's a very old, very specialized lathe for grinding the exterior of cylinders and shafts. It has limited use in a home shop. Having said that, I'd haul it away just to have it to play with for a while.
jack vines
Mickey_D
Austin, TX
If it is not totally worn down from abuse, that would be a wonderful machine to have. Those let you keep the tool post grinders away from your lathe and their fragile ways.
rsanter
visalia ca
if it was local and cheap I would get it
but then I have an afinity for old heavy stuff
bob
Bolster
Mexifornia
Post a question at Chaski Home Machinist. Mostly retired machinists over there; someone probably owns one like it!!
metlmunchr
It is a cylindrical grinder. The only similarity to a lathe is the fact that they're both made for working on round things. For a person inexperienced in grinding, it is one of the most potentially deadly machines in a machine shop.
RoninB4
Under My House
-Have to agree, I've run a few OD/ID and many surface grinders. When something bad happens it's usually instantaneous, no time to get out of the way or even react. Wheels can literally explode, sending deadly chunks of stone flying at terrific speed into or through anything within 20 feet. I've been a toolmaker for decades and I still approach grinders with a healthy amount of respect and caution. Grinders are not a good machine for the inexperienced or to be casual about while operating because of the spindle speed and how fragile grinding wheels are. JMO
