Yes, Not because it is a USA company. Although that is a good thing. They just make some excellent mowers. say'in.
For me it is...provided it is in fact quality. In today's world most things (not all) but most...if made in USA is every bit the tool and or machine it's Asian made counterpart is. Most cases it's better and in some cases significantly better.
I have a 17 year old made in USA Toro recycler 22" that starts the first pull all the time every time.
It had that one pull guarantee horseshit for three years on it.....
After a rope repair to the pull starter....and privided you keep a new filter in it, new plug and oil changed this thing has no end in sight and still does the one pull start 17 years later.
The deck is still like new and has the deck wash feature. It can bag, mulch and side discharge.
The self propeller cable has been rerouted to combat cable stretch...
But this thing just keeps on keeping on.
An educated guess is that it's mowed approximately .8-1 acre about 1,050 times in its life.
There are areas I can't mow with the John Deere....To which is even more impressive.
An lx172 circa 1991. That thing just like the Toro...just starts and goes to work.
Belts...need changing every so often...the mower blade saftey latch on the swutch has broken...now you just push the button in...
The seat has more cracks in it than remaining vinyl...the shift knob broke in half which now has an old Jeep NV3550 shifter knob I sourced from a Wrangler after I changed the shift handle in it...
The orange trottle lever/cable broke one time as well.
It's a simple machine. Gear driven transmission. Mechanical deck lift...
It pulls one thousand pounds or more behind it at times...I've a cart I use for mulch, stone and firewood etc...
Made in USA
