Repurpose lathe stainless steel chip tray
R_C
Wyoming
For my Atlas lathe restoration project I found a set of the original stand legs which came with a large 24" x 65" stainless steel chip tray. Looks to be 14 or 12 gauge. I don't have room for such a large chip tray and my lathe is much smaller. So I thought I could occasionally put the tray on a wood work bench and use it when cleaning oily greasy engine parts. But I would need to fill about 10 holes, some 1/4" and some 3/8". I am a poor welder and I have never welded stainless steel. What are some options for filling the holes?
R
R_C
Wyoming
I was hoping for something smooth both sides so it will sit flat on the bench and nothing to get in the way. Right now my only thought is some metallic tape on the bottom then JB Weld to fill the holes. But I'm not sure that will hold up.
ItsNemo
Canada
Find a local welding shop and have them buzz the holes closed and you can clean it up back at home.
Though welding stainless isn't that hard for something like this, doesn't even need to be TIG, you could MIG it but ideally need tri-mix.
slowtwitch73
Hellgate
^^^ yup.. mig or tig whatever is cheapest and tell them you will clean up. Hit it with a flap wheel on angle grinder.
Jswain
Calgary, AB
Do you have a mig welder? Would be pretty easy if you do & already run c25 gas, just missing the stainless wire.
It won't be as corrosion proof but won't be a problem for this task and would a hell of a lot better then jbweld
R
R_C
Wyoming
I only have a flux-cored wirefeed welder. I did think about bringing it to a welding shop but wondered if there was a DIY solution I might try. I can certainly clean up their welds so that may be the solution.
Jswain
Calgary, AB
You can also get flux core stainless wire if your welder will burn .035
bubinga
I'll repurpose it for you, I'd put my lathe on it (10" Logan)
That thing is NICE!!
R
R_C
Wyoming
Next question. Where does one buy a tank and C25 gas? I'm in rural Wyoming and my initial searches found nothing in the nearest towns but an AirGas and Linde 100 miles away.
Jswain
Calgary, AB
Real nice lathe! You could asking your local welding shop/supply shop about the bottle they might be able to point you in the right direction.
If it is that far get at least an 80cuft tank then it'll last quite awhile for a hobbyist ~1 year or more
R
R_C
Wyoming
Tractor Supply is also 100 miles away. I'll make some calls on Monday. I appreciate all the comments and suggestions.
Jswain
Calgary, AB
If you can get a CO2 tank locally/refills that is also an option
20lb CO2 tank will prob. Be about the same to purchase as a 80cuft c25 but the refills will be much cheaper and you will get ~175cuft of gas. Slightly more spatter & slightly more penetration
You would need an adapter for your regulator as well but they are common and cheap
R
R_C
Wyoming
I read several posts about tanks and refills in these forums and that helped a lot. I just bought a full 80 cu.ft. C25 on Amazon. The tank is within 2 years of its hydrotest date and reviewers say no problem exchanging. Delivered to my door beats the long drive. 80 cu.ft. should last me quite a while and that will give me time to find a closer source for exchanges.
cpttuna
napoleon ohio
unless you are a great ss welder, put pieces of scrap ss on the bottom side and weld from the bottom
