TGNP
Please help, my bolt cutters jaw does not close together. I try to adjust by releasing 2 nuts behind the adjustable screw and trying to turn the bolt clockwise but the jaws are nearly close together and I found it has a gap of around 1 mm.
I try searching for how to adjust from the website as below,
www.wonkeedonkeetools.co.uk
I try to release the bolt holding between the jaws and the handle and start to turn the adjustable screw clockwise again and the same result.
Does anyone have bolt cutters similar to mine please suggest?
Thank you.
How to adjust the jaws on bolt cutters? - Wonkee Donkee Tools
How to adjust the jaws on bolt cutters? The position of bolt cutter blades can be adjusted using either the jaw adjustment bolts, located on the plate that is mounted across the two jaws, or the neck adjustment bolt, located near to where the blade joins the handle on one side of the tool. […]
Thank you.
