Amazon Warehouse Deals
HotRodHudson
Man you had me worried about not having 10ga solid wire stripping ability with the new Milwaukee’s I bought. Thankfully they go to 8ga wire!
I’ve always used a stripper 🤭 like the southwire but have also found I needed a set of needle nosed pliers as well to get the 1/2 - 2/3 of a circle at the end of the copper wire to make my receptacle connections. I’m hoping the new Milwaukee will take care of that duty as well.
skamath
Sorry I was referring to stripping the romex outer sheath, not the wire insulation. Also was referring to this milwaukee: https://www.milwaukeetool.com/Products/Hand-Tools/Pliers/Wire-Strippers/48-22-3070
sorry for the confusion!
Odd-job
Hope someone on GJ got that. Crossed my mind for a second to have another M18 with a countersink bit permanently on it, but then reality hit and between a drill press, m18 gen 2 fuel, m12 fuel, M18 SDS Fuel, plus m12 impacts and I probably have my drilling needs covered for the time being.
GeoBruin
But... how will you countersink holes?
vwpieces
Hills, PA
MAYBEN
Sparta, NJ
Never use your points to buy something= since you won't get points on that purchase.
Cash out your points to your bank acount and use your card to buy whatever so you still get the 5%
Exactly! Although - they have been showing you can use the points and save 20% on certain things, up to $10 in savings if I recall correctly. I ALMOST used it on a purchase THEY suggested, then I saw that they were wrong and it would not have counted!
tmshort
Central IN
What am I missing about these Amazon points?
I have an amazon CC that gives 5% back on all amazon purchases.
Previously, I'd use the points (which are in the form of a cash credit on the amazon acct) to buy more stuff. I didn't know I could get cash for the points until I read the above. I assume this is what people are referring to...
RacerX
Caldwell, Tx
Ahaa! Thanks!
GeoBruin
I'm tempted by that Aircat extended cutoff tool but I can't believe it's not identical to the Harbor freight Chief model. I have several of the Chief air tools and they look identical to Aircat models.
And the Chief is cheaper than the warehouse price brand new!
Anyone have any insight on this?
Odd-job
vwpieces
Hills, PA
vwpieces
Hills, PA
red
Hudson Valley, NY
