sparky 1971
The best pulling lube is Ideal Yellow 77. It's also the messiest and hardest to clean off of surfaces. I put plastic sheeting on the walls and a cheap tarp on the floor. If I were in charge of this pull, I would have a gallon of it and use the whole thing. Throw a little down the first LB, lube the head, then apply liberally as it goes in. Then repeat, but not quite as liberally going from the 2nd LB to the sub.
Have plenty of rags on hand at both ends so clean up can begin as soon as the wire comes out.
Don't tape the wires together unless just just to keep them straight, but take the tape off as it goes into the pipe. I wouldn't bother.
