Hobby_Man22
Is it normal for it to kick back on after only 9 minutes or so of being off and then run for about a 35 minute cycle when it's 100 degrees outside?
I think it has a 6 minute compressor lockout to allow the pressures to drop before it restarts.depends a lot on your insulation . but 9 mins is not terrible
Is this only a heat pump thing? The reason it doesn't shutoff is because it doesn't get below the threshold to shutoff.If the outdoor design temperature is 100, and the equipment is sized perfectly to the load calculation, it would not shut off.
NoIs the same building in other posts where the metal door was 140* surface temperature ?????
Many variables to take into account.
The main thing would be your insulation. If you get the room to your desired temp and then switch off the unit how fast does it take for the temp to climb a few degrees? Most thermostats are designed to come on when the desired temp rises a half of a degree so it can keep the area the same temp.
Where is your thermostat located? If its right by a register you may be getting a false reading of the room. Using fans to circulate the air can help to make sure you don't have a dead spot but is really a band-aid. Place a digital thermometer by your thermostat and confirm the temp is the same, then move to various areas of the shop and see if the temp rises which will confirm a weaker zone and relocation of the thermostat or additional ducting may be needed.
Sounds about right, Texas can get awful hot...It cools about 2.5 degrees below set temp and kicks back on when it is 2.5 degrees above set temp confirmed by a field piece temp meter
I did but the r30 isn't enough. It needs another layer.You comments are confusing!
Insulation is always a good thing, more is better.
Of course more Insulation will shorten run time, that is a good thing!
Everyone has been telling you to add Insulation for months!
If this is the new unit in your shop, it most likely has an internal protection circuit to keep it from restarting sooner than the manufacturer considers “okay.” Check with the manufacturer or the company you bought it from (if you trust them) to be sure.The question is is it okay that it kicks back on after 6 minutes?
Sure, if it needs too.The question is is it okay that it kicks back on after 6 minutes?
If it has a 5 degree swing and rises enough to kick on in less than 10 minutes id be looking at air leakage. Just posted about it in another thread. No amount of insulation will help if the controlled air is getting sucked out and replaced with hot air.I also have a 3 degree offset because it was cooling way below the set temp so the thermostat is in a bit of a dead area. My main concern is that it restarts after a short time like 8 minutes. That was the point of my thread
I've measured mine. It comes out the vent at 52 degreesAttic is the worst place for HVAC.
Duct leakage is a big thing.
The attic may have R38 insulation, but the ductwork, depending on when it was installed, may have R4.2, R6, R8 or R10. If the insulation is installed properly.
Go measure it at the evaporator coil.I've measured mine. It comes out the vent at 52 degrees
