Hardwood tops for Snap-On Box
tampascl
I've got a KRL7002APC that I'd like to put a hardwood top on. Other than the 27 21/32" x 53 23/32" top that SO sells for $384++, has anyone made their own? Other aftermarket (non-SO) options?
alberto
I looked around for alternatives, but ended up going the Ikea route as nothing that I could find was cheaper.
Im putting an Ikea butcher block top on my Vidmar Cabinet this weekend. I bought the top at Ikea 61 x 31 (or so) for $79. I'll cut it in half double it up and trim it to exact size, and I'll end up with a 2.5 inch thick top. Thing weighs about 60 pounds.
iandh
Your best bet for a top of appropriate quality is to buy one of the maple workbench tops from mcmaster carr and then trim it on a table saw to fit.
Slip_Kid
Rhode Island
You could get oak 3/4" tongue and grove flooring for $50.00 a bundle. Glue them together and cut to fit your top. Or get the 1-1/2" thick pre-made oak stair treads ($25.00 each) at 4' long, glue them together and cut to fit.
mojo_13
Iowa
I was going to say the same thing, I have heard nothing but good things about these and will be the way I go when I build my workbench. But depending on how you are planning on using it the IKEA version would work too.
rsanter
visalia ca
home depot and lowes can order different sized butcher blocl tops for cabinets and islands.
you can also order them through the internet or go to a cabinet shop
bob
Vinko
Los Angeles
I didn't know about this from McMaster. Good idea. Probably a lot more reasonably priced than SO.
nate379
Palmer, AK
How about just a sheet of nice plywood? Can get oak or birch. Sure it won't be "as nice" but $50 for a sheet of ply is nicer!
Mickey O
Chicago, IL
That's really not a bad price, but the Ikea idea sounds very interesting, looking forward to the pictures (someone better post some pictures).
mojo_13
Iowa
Just keep in mind the thickness of each one also, I'm not sure how thick the SO top is but the IKEA top is 1.5" while the Mc Master is 2.25" so dependig on what you are doing on this top you may like the extra 3/4" thickness. But like I said not sure how thick the SO top is so it is hard to compare prices.
66HertzClone
Long Valley, NJ
I can vouch for the quality of the McMaster Carr top, it is beyond any doubt a high quality piece. I have one on my first bench and one from another supplier on my new bench. There is no comparison, the new top weighs half the McMaster top, the wood has a much finer and tighter grain than the new one. My tops are 1 3/4 thick.
As we often have said, "if I had only known", I would have spent the extra cash and bought another.
lilredex
Toronto
If you are a bit of a woodworker, you should be able to make something serviceable in your shop. Below are a few tops made from scrap wood that was originally brought home to burn in my stove. The tops range in thicknesses of about 1 to 2", but could have been built up thicker. The first two are finished with "Spar" (marine) varnish. The material is both hard maple and white oak, the 4 X 4" sticks are hard maple awaiting future projects. All this material started off as crates and skids. Not all the wood is suitable, but it is always sorted and saved, as I cut it up for firewood.
T
tampascl
Snap-on is 1 3/4". Ikea is 1 1/2 inches. Will be interested in hearing about the IKEA experience and seeing some pics!
nissan_crawler
Wichita, KS
I used a solid core entrance door. A 36" door will give you plenty to cut the keyhole off for a 30" box. The lip keeps tools from rolling off, a big issue I have with any of the truck store tops.
nate379
Palmer, AK
Even a softwood top would work too.
My Dad's shop countertop is a butcher block top he made out of ripped 2x4s. He built it back in the early 90s... I would say around 91 or 92 and it's still in great shape.
KEH
Find a local woodworker and give him your business. He can make the top out of any wood your pocket book can stand, and might even have scraps he would like to use up. Piece of cake to make a flat top like that.
KEH
stevejh82
I made one for my box out of left over maple flooring. The grade is actually called "rocky mountain", which includes pieces with mineral staining, knots, and other defects. In essence I took some dimensional lumber and ripped it into strips to make a frame under the maple. Then I just laid the flooring across it just as you would on a floor using a flooring nailer. For the end pieces I ripped the tongue side off, mitered the corners and biscuit/plate joined them to the top. Here is the result, which is way better than having that lip sticking up and getting chipped when you lay tools and other items on top of the box.
mojo_13
Iowa
That looks great. I may have to snag that idea from you.
Jack Olsen
Los Angeles
I've got a solid core door above my (Chinese-made) tool box. I've got the Ikea 72.5"x39"x1.5" birch top on a bench in the middle of the garage. I've got a 2" maple top that I got second hand off of a Lista bench on top of my own steel frame on another bench. I've got plywood doubled up on a fold down bench along one wall. (The rest of my work surfaces are steel, between 1/8" and 1" thick.)
The maple from the second-hand Lista bench is possibly nicer than the birch from Ikea. But I can only say possibly. I don't really notice a difference in everyday use. Neither holds a candle to the solid core door, honestly -- and it was only $40.
(And for heavy pounding, there's no beating the inch-thick steel.)
Here's the Ikea piece before I stained it:
Here's the bench with the Chinese tool box and the solid core door:
This picture shows the Ikea one stained, as well as the Lista one in the background and the steel top in the foreground.
Opposite angle of the whole place:
One good Snap On tool box would cost more than my whole garage.
Slip_Kid
Rhode Island
That setup looks sweet, nice job on the garage.
