Best source for aluminum
slloyd
I am starting a project to build a custom truck bed cover out of aluminum. I believe I want 1x1 aluminum square tubing (6061 t6) and cover that with a diamond plate. Where do you recommend to buy materials?
cvairwerks
Within hearing distance of Texas Motor Speedway
1x1 with diamond plate is not going to survive very well. Most diamond plate is going to be .125" or thicker, unless you go to a 5xxx series aluminum.
6061 in square is out there, but few sizes are available, and for what you can get is quite expensive.... 2x2x.125 runs about $11 a foot plush shipping. Select 6063 and lots more sizes and thicknesses are readily available and way less expensive.... half the prices or less.
theoldwizard1
SE MI
IIRC, aluminum extrusion are actually sold "by the pound". Each profile has "pound per foot" associated with it. Easy to change pricing.
corn chip
metalsupermarket is in slc. just go on the website and it shows whats available. there may be other metal stores in that area. buy local and avoid all shipping costs. 6063 does have a wider selection of sizes but its only slightly cheaper for equivalent size. certainly not 50% cheaper like was mentioned.
do you have any design ideas yet ? perhaps you can save a few bucks with a smaller thin wall tube then add some reinforcement bracing. without knowing what your doing its hard to say
BD55
Northern Utah
Triple S Steel is in SLC - I've picked up steel from them but not Al, but may be worth a call to them to see if they carry Al.
ETA: Lol just checked and metalsupermarket mentioned by corn chip above is less than a 1/4 mi away from Triple S Steel. Now I need to go check them out - thanks corn chip!
engineer2
Chicago burbs
In any case, buy it now. One of the largest aluminum smelters in the US will be shut down for 9-12 months. Not sure if it will impact the price of aluminum products.
corn chip
check if they have a remnants pile. basically its the left over pieces from previous customers and its probly discounted. thats what i do when i dont need full length sticks
cvairwerks
what does this mean?
"Drops" are what is left over when someone orders something less than a full stick of material and the supplier cuts off only what the customer orders. I shop my supplier's drops room before I order full sticks of material. I can often find what I need in several pieces there and not have to deal with 20' or 24' sticks.
rlitman
Long Island
6061 doesn't weather that well. 5xxx is what you want for better corrosion resistance outdoors.
Also, 6061 T6 loses its temper VERY easily, which is why it isn't used by bicycle manufacturer as much any more. Frames made from 6061 would have to be welded, and then the entire frame would have to be heat treated. Bicycle manufacturers that still weld tube usually prefer to use 7005 now, because they can weld together heat treated tube and not have a frame come off the welding bench that's as soft as overcooked spaghetti. Not sure if the OP is planning on welding though.
Look for "Drops" whenever you need material.
What remains when some shop buys full sized pieces and cuts off what they need. The drops are often sold as scrap.
PDang
so basically remnants...
Honeyduer
5280 FT
If you are in Denver Colorado take a look at ALRICO. They are near Brighton and have semi trailers full of tubing and all the diamond tread plate in different thicknesses you will ever see in their warehouses.
corn chip
the local metal warehouse here calls them remnants. drops. remnants. its all the same ****
Kuma601
Cali
As a price reference, Alu at my local place is $4.99#, the remnants cuts are $2.69#. Anytime I'm in the first look is the cut-off room for those pieces. The batch I picked up was Kaiser and their stuff is very consistent.
corn chip
I guess. The only place I've heard the word "remnants" used for such things is in reference to carpeting.
i dont know what to tell ya my freind. thats just what they call it here. if ya want their phone number maybe you can convince them how wrong they are.
dictionary definition of remnant ,and i quote , a small remaining qauntity of something.
if all those small pieces of various metals dont qaulify as remnants then what the hell does ?
VR6ix
Onterrible, Canuckistan
Funny how quick a thread will take a turn away from the original question lol... to add to that, at my work:
- "remnants" are what we call the left over sheetmetal and plate after laser cutting when it's going to be saved instead of scrapped. AKA "rems". The junk that gets scrapped is called "skeletons" because their purpose is to provide support for the cut parts.
- "drops" are left-overs from saw-cutting tube and structural shapes
For what the OP is looking for, 6061 versus 6063 tube, round corners versus square corners, it's not going to matter much. For a truck bed skin 1/16" checker should be fine with a well-designed support structure. Welding 1/16" plate to 1/8" tubes should be no problem for a 200 amp machine.
If it was me I would hand-sketch in detail what I was looking for and then visit local fabrication shops and see which ones would give me the time of day. Cash and/or beer goes a long way. Ask them for their input on the design and get the skin laser-cut and formed as needed.
Monza Harry
Windsor ON
Unless its a buddies shop - no fab shop works for beer.
Showing up on a Friday night with a young crew it will, the shop doesn't profit but it will buy products and services! Not the right thing to do, but seen it done lots over the years, however around here the staff has aged so not quite as effective as it has been in the past. Harry
