ALL THREE...
You didn't have three as an option you say...
Allow me a moment to explain.
You need both you listed plus...
Angled wrenches like these
shop.snapon.com
Examples why needed...
Super Duty power steering line.
I don't recall the year (2005 perhaps...)
The one power steering line the only way to remove it on the truck is with a crow foot. Now if you remove the mounting fasteners and reposition but as it sits in the truck you need a crow foot 18mm.
Chevy tahoe/silverado's / GMC Yukon/Sierra's
are especially bad for needing all three if working with the abs units. Say you need to replace the abs unit but the lines are fine.
You'll use all three.
Matter of fact on almost all ABS units when removing lines you're going to use all three and often times the angled wrenches will be used the most.
If you're in the rust belt I'd highly recommend the flank drive plus if buying angled wrenches.
Maybe you're only replacing one bad line at the abs unit. Again on a tahoe/silverado platform it's damn near impossible to cut the inner lines as 5 other lines are conveniently in the way to get a cutting tool with enough power to cut steel OEM lines in there to do the old (cut line near fitting and use six point socket to remove trick)
Again this is where the angled wrenches are priceless. Flare wrench might not work pending how the fastener is sitting and the other lines limit clearance.
The angled wrench if it won't work one way flip it over and it will work the other way for sure.
My personal preference on brands...
Crow foot flare wrench set...Snap-on
Flare nut line wrenches...MAC (USA made) fit the best in my hand
Angled wrench...Snap-on...being in the rust belt the flank drive plus is a huge asset
Line wrenches...
MAC and SK have the best Chrome IMO of all brands
Gear Wrench are definitely the biggest flare wrenches I've seen. They're massive which can be an issue at times.
Goodluck
