I was using a Gearwrench 81119 1/4" drive wobble extension with a Gearwrench 81224 1/4 drive Roto Ratchet with a 10mm Snap-On shallow socket to remove two EGR valve bolts. As I applied torque to the ratchet it felt like the bolt head was about to twist off. It turns out it was the tip of the wobble extension twisting. This was the first time I have used this extension! I ended up borrowing a Snap-On wobble from a co-worker so I could remove the bolts and finish the job.
The tip isn't completely broken just twisted enough so that a socket won't go on smoothly and it won't allow a socket to wobble any longer. Instead a socket is now held very poorly at a crooked angle. The retaining ball is also pinched by the sides of the hole and has seized in the extension.
I received this 4 piece set of 1/4" drive wobble extensions from my girlfriend as part of my birthday gifts just days ago. I am sure they will warranty it for me but will the new one fail as well? I have bought a lot of Gearwrench stuff in the last few months and this is the first item I have been unhappy with but, I must say, it has me a little worried that it might be the first sign that I should have stuck with Snap-On.
