Thanks for the compliments, I will.@rayra - please start a build thread on your outdoor kitchen/cooking space!
It’s clear you’ve got some serious skills and master plan cooking!
Nice work and thank you for sharing the process.Any progress on your pours?
I finally got the stuck beveled inserts out of my cast lintels. still need to get some paint off the concrete without marring the pieces.
The big 'concrete stuff' topic will be delayed, surgical schedule got re-arranged and I'm busy on other things.I have to get some image-hosting directories straightened up in my own domains, as well.
The other 2 pics are mockups of the grill island layout, the dog house standing in for a domed pizza oven I'll be building late in the year.
Thank you and yes it is partly full height and the opening is for 6’ wide french doors.I hadn't quite realized that is a full-height room there. I'd thought it was a shorter space under a room addition. Looks good and nice setting of perimeter bolts in the lintel.
Does that space connect thru to the basement? Looks like you've made the opening large enough for double doors, so I presume so.
Thank you and the plans call for compacted #57 washed stone backfill there same around the outside walls.Looks great
Are you going to backfill behind that retaining wall with concrete?
I just saw that you escaped from Los Angeles, same here even I would not call it escaping on my end but I really like the four seasons, the green and the mountain ranges here WNC.Seems bigger and bigger every picture. That's a lot of volume. Could store a lot of supplies in there.
Are you in the hurricane part of NC or the ice-storm-snapping-trees-killing-power part?
I look at all that space and I'm thinking water tank, fuel storage, generator, piles of canned goods. I wish I had that kind of new volume.
Yes indeed, the walls in the circled area are treated like exterior walls on the inside so some walls will have water proofing, gravel, etc. on both sides and there is an 8” pipe at the bottom of the exterior wall to the right of the ladder for the drain pipe.Make sure you water proof the uphill side of the interior retaining wall (circled in red) and provide appropriate drain tile and stone and connect the drain tile to the exterior. This will keep your storage shed portion dry. Many folks forget this!
Obviously the other exterior portions need to be treated the same.
Thank you for sharing and please feel free to post the progress of your project here.well we were talking about 'retiring' in a few years to E.TX somewhere around Tyler, 40" of rain. But covid came along and disrupted everything. So we cashed out of L.A. and moved out of CA but tried to stay close to my aged folks in Temecula, so we wound up in Vegas. And then they upped and moved too. So here we are in a terrible desert with an empty lake.
But we lived on all three coasts and multiple continents during my father's Naval career and a few places in my time in the Marines. But in SoCal most of my adult life. But I remembers Seasons in Great Lakes IL, Thurso Scotland, Tokyo, Rhode Island, Pascagoula, Honolulu.
Can't wait to finally get somewhere wet and green where I can grow things.
One improvement of Hurricanes vs the Three Seasons (fire mud and earthquake) you listed for SoCal - you get about a week of warning for a hurricane. I was on top of Northridge '94, lost my house. And almost burned out 3x in Santa Clarita and on the Kern river. Good Times.
Looks like you've got a full slate of projects. May it all go well and congrats on also getting out.
guess you made the stemming stones ... what is the red thing. also what do you use for color.ha, just shoehorning it in your topic
A little in the 'what did you do in your yard' and 'what did you do in your garage' topics.
I ought to have a project topic. But I will probably do a collective topic on several concrete-related projects very soon. I've been working on several interconnected things with various molds and forms that folks seem to find interesting. And I usually do 'how to' topics on lots of things.
I'll be casting a large concrete countertop and building a domed pizza oven later this year. I should have some dedicated topics by then. Right now I'm working on setting / adding the walls (with lintels) for the 8' x 6' cooking island. Propane grill docked on one side, charcoal weber inset on the offside and pizza oven / patio fireplace on the other. Lots of concrete, travertine and plaster work to come.
The red mat is a tough silicone texture stamp, simulating a slate texture.guess you made the stemming stones ... what is the red thing. also what do you use for color.
I have to make some items and I want to make them gray ..... it's been a long time since did any forms. the columns are interesting
Stuff I used years ago was a powder that was mixed into the small batches (bags) that I made up and mixed in one of those barrel mixers. Took a lot of time .... but -- I was just playing around.The red mat is a tough silicone texture stamp, simulating a slate texture.
It was wider than my pavers by several inches in both dimensions, so I numbered the back #1-8 at the corners and midpoints and #9 in the center and each paver I lined up the mat on a different number so I would get some deliberate variation in the textures of the pieces.
There's two kinds of dye, 'integral' that you mix into the concrete - and comes in either powder or liquid - and a 'mold release' that is spread / cast upon the surface of the damp concrete as a dry powder, you put the texture piece over that and stamp it into the surface of the cast piece. When it cures your hose off the excess.
Integral has a wide variation in how much you need to overcome the natural gray of the concrete / mortar. I was using 3-4oz / 60# bag straight khaki for the pillars. later when I made the custom capstones for the wall I wanted things a little lighter so I did a mix of the khaki and titanium white. Running around 2 to 1, khaki to white. But you still have to go high on the khaki to get enough brown in it.
If you want gray, it ought to be real easy and likewise the darker colorations. You may have to do a couple test pieces to get close and keep in mind the color changes over a couple weeks as the concrete cures, getting generally a bit lighter.
I got both types of dye powders from WaltTools, via Amazon. Both are listed as 'khaki' or other versions of 'brown'. It looks the same to the eye, but the surface release powder is water-phobic, do NOT mix it into concrete it will wreck the integrity of the cast.
The stamp I also got off Amazon, as well as the plastic molds for the pillar pieces, differing vendors.
I takes a lot especially in the lighter colors and the stuff is not inexpensive, so some folks try to short it / stretch it. Doesn't work. But white is a tough thing. Would probably be better off whitewashing the concrete pieces at least a month after they've been cast, to get a good bond.Stuff I used years ago was a powder that was mixed into the small batches (bags) that I made up and mixed in one of those barrel mixers. Took a lot of time .... but -- I was just playing around.
I have specified colored concrete on a couple of projects -- one was mixed at the plant and I had to pay to clean the truck (not cheap). I have also used the powder .... both times a product made by SIka. The last I did white and I'm still dealing with a less than perfect job
Good thinking, I was lucky and able to borrow a mixer from a friend.one other thing on DIY concrete work. We found a decent stone / landscaping yard here in Vegas, they wanted $600-1000 EACH for columns similar to these, delivered. Molds were ~$275, mixer was $225. Concrete was about 10 bags per column + 7 per footing, x4. Dye about $40 ($50 today), call it a little over $300 last year for the concrete mix. And a shitload of labor. But for the retail cost of 1 column I made 4. And I've still got the molds and mixer. Which I'll probably sell off after all my concrete work is done. The grill island, pizza oven. Some more footings for a 10x10 floating deck in the middle of the yard. And sometime this coming winter / spring about 75' of side property wall extensions. I'll hire out the footing and block laying work, but might run the mixer / concrete production to 'save' some $
eta at it's 0925 and I've screwed around and it is almost 100F out there already, heading for 111 today. Not getting much done out there THIS morning.
Have you even used colored glass -- the guy doing the exposed on my patios and steps used some in a sidewalk project I just took a look at .. sort of liked it. Have not had any opportunity to speak to him directly ....one other thing on DIY concrete work. We found a decent stone / landscaping yard here in Vegas, they wanted $600-1000 EACH for columns similar to these, delivered. Molds were ~$275, mixer was $225. Concrete was about 10 bags per column + 7 per footing, x4. Dye about $40 ($50 today), call it a little over $300 last year for the concrete mix. And a shitload of labor. But for the retail cost of 1 column I made 4. And I've still got the molds and mixer. Which I'll probably sell off after all my concrete work is done. The grill island, pizza oven. Some more footings for a 10x10 floating deck in the middle of the yard. And sometime this coming winter / spring about 75' of side property wall extensions. I'll hire out the footing and block laying work, but might run the mixer / concrete production to 'save' some $
