teodog
PNW
Xcelite Plier, 5, Needle Nose - $7.49​
Model - NN54VN. ESD safe. No picture shown in listing
Made in China. I have these, nice pliers for the price.
Below is a picture from another site.
$34.13 at Zoro.
tmshort
Central IN
$34.13 at Zoro.
For some reason links are taking me to the prime day home page not the item.
ER70S-2
$34.13 at Zoro.
I have a few Xcelite needle nose pliers and they are amazing. The grips are so soft and squishy. Probably not durable, but they feel great. I'm definitely picking these up.
macgee
Sepulveda Pass, CA
V
vwpieces
Hills, PA
$34.13 at Zoro.
5 posts and already posting deals... (y) (y) Nice!
Welcome to GJ
gamp945
Looks like $55 is nearly an all-time low price on these. I picked up the XL pliers wrench for $40 a while back and have used them once :D Be aware that the XL size is H U G E.
bubinga
if you don't mind putting the price you saw it for in the post, that would be helpful. Even if one misses out, then they have an idea for future reference.
IIRC they were $114.00
or $118.00.
I really like my set.
Some guys don't like them though.
I like the length too for leverage, as I'm not as strong as I used to be.
Wolfe 21
Think I paid roughly 75-80 for both mm and sae in the end of 2020. Will second the opinions above. Useful for leverage and I like the ratcheting end. Great for oil changes if you can get under the vehicle.
webscrounger
Midwest
I believe the 16" Knipex are shipped from Amazon Global Store, UK. I have ordered several Knipex pliers from them and have had not issues. Know that delivery will probably take a lot longer than if shipped from an Amazon U.S. warehouse. Probably a couple of weeks, if they are in stock. I waited a over a month once for some that were backordered. Still, their prices are worth the wait.
BTW, I did order them. At $54 I couldn't pass. I have an estimated delivery date of 8/2.
brandonsmash
We are unable to ship non-digital items internationally to customers identified as businesses. Please choose a domestic shipping address to proceed.
You can visit your domestic Amazon store to access millions of products for delivery to your domestic address.
Well **** you too. I spend many thousands of dollars with Amazon and you're not able to fulfill an order BECAUSE I spend a lot of money?
PressOn
Wisconsin
Um, ALSO be aware that this will lead to Knipex addiction.
I bit on a pair a while ago, and now I keep buying more...
They are REALLY nice.
Also, if you want to drool, go to KC Tools. German only, daily deal, and excellent pricing.
ymmv
Press on, healthfully and prayerfully.
Wolfe 21
Wow!
That was cheap.
I think I remember that I think you got the second set free or something?
75-80 for each set. I caught the metrics on sale over the holidays and got a set of sae on eBay that summer. I do remember the buy one get one, but I wasn't smart enough to buy then.
teodog
PNW
Fall Protection Harness
3M DBI-SALA Exofit 1100301 - $73.32
3M DBI-Sala Exofit XP Vest-Style Climbing Harness 1109728, X-Large - $58.50
3M DBI-SALA 1000555 Derrick Tongue Buckle Belt, Work Positioning Rings, Tongue Buckle Harness Connection Buckles, X-Large - $50.76
3M DBI-SALA DeltaComfort 1100884 Fall Arrest Kit with Back/Front/Side D-Rings, Tongue Buckle Leg Straps and Comfort Padding, X-Large, Navy/Yellow - $35.61
teodog
PNW
3M Finesse-It Buffing Pad - White Foam, for Finesse-It Compound - Paint Shop Coating and Surface Repair Pad - 5.25" - 1912. $13.94 ($1.39 / Count). Qty 10.
3M Specialty High Temperature Masking Tape 5501A, Tan, 1-1/2 in x 60 yd, 32 per case - $28.38 ($0.89 / Count)
3M Crepe Masking Tape 202, Tan, 12 mm x 55 m, 6.3 mil, 72 per case - $23.98 ($0.33 / Count)
...and for those really big masking jobs...
3M High Performance Masking Tape 2693, Tan, 57" x 60 Yards, 7.9 mil, Untrimmed, Plastic Core - $40.01
teodog
PNW
3" sanding discs
FYI - here is a pic of a TSM mandrel. 1/4-inch diameter shaft fits tool collet
3M Roloc Fibre Disc 501C, 60, TSM, 3 in x NH, Die RS300VM- $3.90 ($0.08 / Item). Qty 50
3M Roloc Disc TSM 361F, Cloth, TSM Attachment, Aluminum Oxide, 3" Diameter, 80 Grit (Pack of 50) - $8.45 ($0.17 / Count).
3M Cubitron II Hookit Cloth Disc 947A - 80+ Grit Sanding Disc - X-Weight Backing, Hook and Loop Attachment - For Random Orbital Sanders - 3" $5.41 ($0.22 / Count). Qty 25
teodog
PNW
3M Hookit Microfinishing Film Disc 268L, 100 Mic, Type D, Black, 5 in x NH, D/F 5HL, Die 500FH - $5.02 ($0.20 / Count). Qty 25.
3M Cubitron II Hookit Cloth Disc 947A - 120+ Grit Sanding Disc - X-Weight Backing, Hook and Loop Attachment - For Random Orbital Sanders - 6". $5.41 ($0.22 / Count). Qty 25
3M Hookit Film Disc 375L, Aluminum Oxide, 6" Diameter, P400 Grade (Pack of 50). $5.75 ($0.12$0.12 / Count)
3M 02537 Production Gold 9" x 11" P600A Grit Resinite Sheet. $12.30. 50 Sheets
3M Flap Disc 546D, T29, 4-1/2 in x 7/8 in, 36. $13.89 ($1.39 / Flap Disc) Qty 10
3M(TM) Green Corps(TM) Cutting/Grinding Wheel, Ceramic Aluminum Oxide, 7" Diameter x 1/8" Thick, 7/8" Center Hole Diameter, 36 Grit, 8500 rpm, Green (Pack of 20). $18.80 ($0.94 / Count).
teodog
PNW
I use this stuff in the garage instead of Band-Aids......goes on like electrical tape. Can be used with a piece of Wypall for larger mishaps.
3M Health Care 1533-1 Paper Surgical Tape, 1" x 10 yd. Size, Tan (Pack of 120) - $24.97 ($0.21 / Tape).
teodog
PNW
appleton
