It ran when I parked it …
Half-fast eddie
Virginia
Milwaukee 3/8” vsr drill model 233-02. 20+ yrs old. Cord has been replaced twice, no other maintenance. I love that drill. Last used about 3-4 weeks ago, ran fine. Today … plugged it in, pulled trigger … nothing. No smell, no smoke. I plugged in a different tool and verified power to the outlet. Any ideas?
seber
Deep East Tx.
Those black plugs on either side with screwdriver slots are brush covers. Screw them out and the brushes will follow. As long as there is carbon left they should be fine. It would be highly unusual for them to fail without notice.
bob15
Northeasten, CT
It passed that test. Or didn’t. Whatever ... smack had no effect.
How can i tell if the brushes are bad?
Brushes won't go bad with the drill just sitting there.
I would moving the forward/reverse switch.
What makes you think the cord is still good? One drill - 3 different cords?
Davefr
OR
Maybe when the cord was last replaced it wasn't a good connection. Don't the wires slip into slots on the trigger? Maybe they weren't pushing in all the way. It's easy enough to remove the shell and find root cause.
H
Half-fast eddie
Virginia
The cord was replaced because it was so badly cracked.
Just for fun I will pull the brushes, easy to do. Then open the case.
American Locomotive
Rhode Island
Brushes can stick from sitting, so worth a try to test. It's possible the switch unit died, but once again, very unusual for it to fail while sitting.
I'd place my bets on a loose connection or a break in the cord.
webscrounger
Midwest
I've had similar problems with corded Milwaukee Sawzalls. Variable speed switch (design) issue. Bang it and is sometimes works (once maybe), mostly not. A copper brush inside the switch weakens with age/use and fails to make contact to adjust voltage/speed. Replacing the switch is the best fix for this. Re-adjusting the brush to make contact just doesn't last if it works at all. Don't know if your switch internals are the prone to the same problem. You could measure connectivity/voltage into and out of it to see if that is the issue. Just a thought.
lardy1
Timely thread. I just today changed out the switch on my old 80's era Milwakee 6365 circular saw. The original is obsolete and the new version is wired differently if you ever need to change one. It's simple but the switch doesn't inform you or give the different wiring needed for it to work.
The Cobbler
first thing I'd do is make sure power is reaching the switch ( from the cord) , next see if power is passing thru the switch,either by checking continuity or voltage then check the brushes to see that there is continuity to them . then look deeper .
metaldad
nw indiana
50 years of power tool use, some beat into the ground.
never had a problem with brush problems.
and, i repair my tools
usually the cord or the switch.
in the case of metabo grinders, it's the damn pc board
